Stock Backspacing
does anyone know the stock backspacing for the nbs sierra sle1 2wd
First - no I do not know an answer for you. Sorry. But do you need it for a stock 17x7.5 wheel or was another width available? Was the 20" a 20x8? Backspacing (& offset) could vary based on what size wheel you want specs for.
But on a related note --- why do most truck people want to know backspacing specs while most car guys need offset? (I DO know what each are on a wheel how and how they are related) --- but why the need to maintain specs on both?
Generally the OEM spec is expressed in offset and aftermarket wheels are shown either offset of backspace. Backspace is most often used when describing very wide wheels. Here is a good explanation of offset:
Offset Explanation
Backspace is the distance from the mounting hub and the plane of the back flange and is shown in inches. Offset is the distance from the over width the centerline of the wheel lies expressed in mm (generally.)
Offset of a reasonable width OEM wheel is convertable to backspace and that measurement can be applied to a much wider aftermarket wheel with some level of assurance that the wheel will not rub the frame if turned sharply. There is no level of assurance however that the ride or handling will no be effected adversly.
Offset and backspacing are two totally different things. Backspace is distance from the hub to the back edge of the wheel and offset is simply a measurement of the hub mounting surfaces variation from wheel center. Both can be used for wheel fitment IF you have some other data.
Custom truck wheels are often much wider than stock and backspacing becomes an issue for brake and suspension clearance issues. Offset is really only a valid measurement for wheel comparison if the two wheels are the same width.
i was wondering because i am thinking of installinf the CST 4.f spindle kits and i was wondering if i would have to purchase new wheels
my question still hasnt been answerd i have the oem steel wheels and all i need to know is the backspacing on it if anyone knows
+31mm offset and the backspacing should be around 5-5.25inches
thats the best news i have heard all day hopefully that means the CST lift i am looking at will fit. new wheels are just not in the budget right now
