Sonoma Steering Box?
daviddsims
Hey guys just wondering I had my 02 Sonoma at the lineup shop the other day and they lined it up. They said I needed a new steering box. A guy at work told me that most chevys usually have a allen screw and locknut that you can adjust the slack out. I looked everywhere and cant seem to find it. Does the Sonoma just not have an adjustment on the gearbox? Thanks
    • Mobil up another dime this am , $3.89, others will probably go up later. Any ideas on the reason for the increase other than greed? I've been working 14 hour days and haven't caught the news in a few days.
    • AMSOIL SS is about prevention and it is very good at it's job. I've never seen it claim to be a cleaner however like Valvoline R&P. Almost any oil that has some Ester or Alkylated Naphthalene in sufficient quantity will do a good job at keeping the rings functional.     I see the market splint among these types in two groups; those that use the same tech in every weight grade and those that reserve the tech for the EPA (EPA) friendly grades. Mobil 1 for example keeps the Advanced Clean chemistry out of the SAE 40 and up weights. Other like HPL (top shelf group and No-VII), Red Line HP, TORCO, MPT30K use the tech in all grades. Just not something the Wally World oils are into.
    • Max Trailering Package.  RPO code NHT.   includes 3500 HD Frame, 3500 HD Leaf Springs, 12" Rear axle and 3500 HD Shock Package.   GVWR goes to 11,750lbs for crew cab standard box 4x4, 11,900lbs for crew cab long box 4x4.  2WD crew standard is 11,500lbs, 11,550lbs crew long 2wd, and 11,450lbs on regular and double cab 4x4.       There is also NHT on 1 ton dually regular cab 2WD.  includes 3500 HD Frame, 3500 HD Leaf Springs, (F60) Heavy Duty Front Spring/Camper Package, 12" Rear axle, 3500 HD Shock Package, and Z6A Gooseneck / 5th Wheel Prep provisions with bed stamped holes and caps.  GVWR of 14,000lbs.
    • https://www.msn.com/en-us/autos/general/what-makes-this-1963-ford-falcon-red-rocket-special/vi-AA2asoRz?ocid=winp2fptaskbarhover&cvid=be9c1b4f79ff4211c526abd60f6da012&ei=16
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
