Anyone Ever Tried Acetone?
That article does not disprove the theory or application it only says it's not a good idea because of the unknown damage to the engine, etc. I'm certainly not claiming it works but I don't think that article debunks anything either.
As soon as I find the appropriate vehicle to try it on (one out of warranty) I just may. I wonder which of my friends I can convince this is a good idea?
I don't know how it can work without causing some damage along the way. Acetone is a very strong solvent. I'm not debunking the theory, hell, it's probably the best kept secret that our government doesn't want us to know about. Just my.02.
It might work but at a cost. Acetone would probably eat rubber seals... starting with the fuel pump. It might take a while but I bet it would damage something.
That's my might and probably theory! :)
That's my might and probably theory! :cool:
it will and quickly
it will and quickly
Proof? That's ultimately what we'd all like to see, not just "it will", that's the point of this thread.
Ok, I feel it time for a science experiment.
I am going down to Autozone, and buying myself some o-rings and some fuel lines. I am going to submerge them in 100% acetone, and leave them in a covered beaker for 30 days. I will also place another piece of fuel line and o-ring into another beaker, and this will serve as my control variable. I will leave them in a dark room in my lab, and see what happens to the o-rings and to the fuel lines. I am submerging the entire line in order to simulate a "worse-case-scenario”. If it dissolves the lines, then it would be safe to say that damage may occur with long term use. If the line are okay after 30 days, then I believe that our fuel systems will be okay. I know that there are other components in our fuel systems, but in my opinion, the fuel lines and o-rings seem to be the one more vulnerable to the effects of acetone. Does anybody have anything else to add to this experiment? I will keep you guys updated with this experiment. Any suggestions, please be sure to add. Also, if others want to replicate it, it would be interesting to see the results.
-Al
By the way, my hypothesis is that :
"I think that the acetone will begin to dry out the rubber fuel lines and o-rings, and cause them to become brittle within 30 days."
-Al
Put one of the beakers under a hot lamp to simulate the same temp under the hood or vehicle
I am going down to Autozone, and buying myself some o-rings and some fuel lines. I am going to submerge them in 100% acetone, and leave them in a covered beaker for 30 days. I will also place another piece of fuel line and o-ring into another beaker, and this will serve as my control variable. I will leave them in a dark room in my lab, and see what happens to the o-rings and to the fuel lines. I am submerging the entire line in order to simulate a "worse-case-scenario". If it dissolves the lines, then it would be safe to say that damage may occur with long term use. If the line are okay after 30 days, then I believe that our fuel systems will be okay. I know that there are other components in our fuel systems, but in my opinion, the fuel lines and o-rings seem to be the one more vulnerable to the effects of acetone. Does anybody have anything else to add to this experiment? I will keep you guys updated with this experiment. Any suggestions, please be sure to add. Also, if others want to replicate it, it would be interesting to see the results.
-Al
I think this is pretty cool. Bringin' the class room to GMTRUCKS. I like it. I can't wait to see some results. :cool:
-Al
Good idea. actually, I would need to put both beakers under the hot lamp to keep the investigation accurate. The only variable we want to change is the liquid the line are exposed to (independent variable).
I went online, and I googled this. I have yet to find someone who has done this, and end up with damage to their vehicle. If you all find a case, be sure to let me know. I don't know, but my hypothesis may not be supported. We will wait and see.
Again, any suggestions would be wonderful.
-Al
-Al
I am very excited to hear the results although I'd suggest having one beaker with the recommended blend of gasoline and acetone in addition to the pure acetone beaker. It would be more similar to the real world conditions.
Also, you might try grabbing fuel lines and o-rings specifically designed for running E85 as well as they are certainly a different compound and should show different results. Perhaps us Flex Fuel guys may get lucky!
