2008 2500 Hd Factory 265/17 Tires Rub
The dealer installed my mud flaps yesterday and now when backing up and turning they rub...they also rub when turning sharply going forward. I have the non-form fits. Has anyone else had this problem and is there a fix? Anyway to trim and still keep it looking clean too?
Thanks for any help anyone might have!
Well looks like GM is going to cover it under warranty not sure what the outcome will be...crazy they would put to big a tire on a truck from the factory that rubs. Amazing i am the only person with this problem.
Front end only? Get a leveling kit. Stock tire size for the 2500HD is 245/75 so Im confused as to how you have a 265/75 standard.
comes from the factory with 265's and the Z71 package. Must be a new option this year?
17" Factory 17" wheels came with 265/70/17,your right for the 16"
Oh, I didn't know they were putting 17"s on them now.
I have the stock 17" wheels and installed the GM molded mud flaps. I think the 17's come with the LTZ option. Mine also rub in reverse with the steering wheel all the way to the left or right. I have not had the time to determine exactly where they rub so I can see if a little trimming will fix it.
Yup. mine rub a bit too! Z71 option. GMC flaps. Tires LT265/70R/17's. So what. They rub a touch at certain turning situations. Doesn't hurt anything. Just glad to finally have a decent size set ofwheels and tires on these trucks. I always found the GM's to be a bit undersize for the 3/4 tons.
Well I have mine down to only rubbing when I back up and turn in either direction.
So what? I guess I expect a little to much from GM and could do with out the sound of it rubbing. I dont think anyone said it was hurting anything but more less loooking for a fix. My fix was adding another screw and taking the saw to the flaps. To me this is just the little things I get tired of dealing with and shouldnt have to! I don't like squeaky doors on new trucks either...go figure!
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
    • I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.   One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
