Tranny Flush At Dealership
Went to the dealership for a transmission flush and filter change. No time or space to do it myself right now.
It's probably not possible to verify if they did the flush or not, but I really don't think they dropped the pan at all to change out the filter.
If I really believe they did not change the filter, how should I approach them? Or do I just forget it and never come back?
Check the fluid. I don't see how that wouldn't tell if they did the flush. As for the dropping the pan, without dropping it and checking it yourself, you probably wouldn't be able to tell. Next time, mark the bolts and you'll be able to tell if they did or not. This is why I try to do everything I can myself.
I'd look under the truck at the pan and see if a new gasket has been made or if it looks cleaner than usual. There might be some type of evidence showing maintainance was done especially if there alot of fluid stains on the bottom of the pan on half the side
I know from personal experience, a flush at a dealership (or most mechanic shops for that matter) is not what you were looking for by their terms. You wanted a pan drop. If they gave you a "flush", all that they probably did was hook the machine into the lines and flush about 18 quarts of new tranny fluid through your system. This is in their literal terms, a "flush". You didn't necessarily get screwed, but rather mislead. Technically speaking, if you have been regular about your flushes; i.e. every 30-35,000, you don't really even need the pan dropped (in most circumstances). I take this information from working at two different shops, being ASE certified in lubricants, and under very good master mechanics. Some may disagree with this information, which is fine, but I have never personally had a tranny problem by following it. Either way, hope this solves your inquiry about the flush.
p.s. if your fluid is very pink, the flush was probably done....if brownish or tan in any way (even orange) take your truck back immediately and call them on their bluff
The majority of shops that do tranny flushes don't like to drop the pan. They're afraid they will have leak problems after the re-install. I've had this issue before.
A tranny flush at our dealership DOES NOT include dropping the pan/changing the filter.
You have to pay extra for that if you want it done.
I'd rather drop my pants than than do a flush.
Experienced trans mechanics can "read" the tea leaves in the droppings that are in the bottom of the pan.
If the trans is have a wear issue, you will never "see" the problem by flushing.
But, then again, doing a pan drop THEN do a flush with the machine that does a reverse shock. That would be the ultimate.
I realize their "Powerflush" does not necessarily include a new filter and gasket. And when I dropped it off, he said I wouldn't need a new filter. But I specifically said I would like a new filter. He said OK and said he would add it in at no charge since the promotion they sent me in an email specifically said all new fluid, new filter and new gasket.
Let's just say I know they didn't touch the pan since I placed a seal on the pan that has not been broken. And had they done the job this seal seal would be imposible to put back in place the way I had it. Gotcha!
It might have just been an oversight since they tech just thought it was another run of the mill flush. Or should I trust these guys at all?
Most have read my opinions on the new technology of 'flushing'. Whether it is under pressure or no pressure.
I am against it. I had one transmission fail after a 'flush'. Granted, it was an old transmission. But it worked fine before the flush and failed after the flush. And all the old car magazines are against the flush. Yes, granted, we are probably not talking about old trucks here.
All these dealerships and independent shops and mechanics have been sold this machine and they have to pay for it. And they want YOU to pay for it.
Here is one of the lowest price machines that cost $4,000.
And the price of these machines goes up from this base model.
And many/most do not drop the pan and change the filter. Some will but you have to be pro-active and ask for this. Then pay extra for this.
Just have the shop drop the pan and let good old gravity drain the fluid. And replace the filter and gasket. Less money.
Oh, I hear the money people screaming: "Not all the fluid is changed this way"! Ya, so what. Do this on a regular basis and your transmission will last much longer. Period.
The End.
    JimmyB4
    JimmyB4
  • Who's Online   3 Members, 0 Anonymous, 755 Guests (See full list)
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
