Towing Question: Do Oem 20" Kill My 3.73 Gears
Group,
I towed with my '07 VMAX 4X4 for the first time last week. We made the trek from California to Utah (850 miles each way) and back with a 14' Big Tex utility trailer carrying a Yamaha Rhino and quad. Total weight is approximately 3,800 pounds. I was a bit surprised that it struggled on some of the big grades (like the Baker grade on 15 for those around the Vegas area). The load was enough to force some 2nd gear climbs. The standard MAX is rated for 9,300 lbs I believe so this was well under ½ the maximum allowed towing weight. The truck has 3.73 gears and the factory 20" wheels. I'm seriously considering buying some of the Z71 18" take-off wheels as I will be towing this toy trailer quite a bit. The total average mileage was 9.8MPG according to the DIC and tranny temps ranged from 150 – 205 degrees. Engine oil temp climbed to 255 Deg. During the Vegas portion (100 deg. Air temp) Unloaded I average 14-15MPG on the freeway.
Any thoughts? Are the 20's really lowering my effective gear ratio that much?
Thanks,
Steve
Irvine, CA
* Did I mention that I LOVE my GMT900 truck.
Jeff, can you have a VMAX with 3.73s. I thought they only came with 4.10s.
Wake up, Jeff. Somebody's poking you. :rolleyes:
Mine did not have the MAX-Trailer pack which I think dictates the 4.10 gears. The RPO code on mine is GT4.
-Steve
Its more rotating mass and overall diameter. If the overall weight is the same and overall diameter is the same switching wheels and tires will not help much. Lighter wheel and tire and shorter overall tire height is the ticket.
+1
I also have 3.73s. I think the tow rating is more like 8,500 lbs. Still though not even close with what you are towing.
Josh
Were you using the tow mode? As mentioned above, it is the overall wheel/tire diameter that will influence the towing ability. If you actually went to lower profile tires with a smaller size wheel, that would definitely help.
Except then you may be going too small for the load you are carrying. I don't know what they are off the top of my head buy you need to stay within your load rating.
    • I have ordered the car link adapter and registered for the google dev, will need to finish verification process later this evening when I get ahold of our kiddos android tablet. I will be using windows vs mac so hopefully it goes smoothly. I have zero tech background but I feel I can manage this with your write up.    Do you think it will be different for me? My truck is a 2023 GMC 1500, I have looked heavily into the AI boxes but I consistently find common complaints with lag.    Does carplay auto open now that you have it set up when you get in truck and turn it on? Or do you have to do open the app everytime?
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
