Flywheel Spacer
chvowner
2006 Chevy Silverado/ 3/4 ton - I have the new flywheel and the new spacer but there wasn't a bolt to fasten the two together. Apparently it is an 11 mm hex bolt but can't get my hands on and didn't come with kit. I called GM direct and she checked with someone who said that it is a regular bolt and could get at a hardware store. Can't find. Am I getting wrong informations someplace? Help. Truck needs to get on road soon. :D
The bolts that attach the flywheel to the crankshaft go through the spacer. The bolts I think you are talking about are to remove the spacer if it is stuck on the crank.
