The Next Poster
Wingnut
This is where you rip on the NEXT poster, not the previous one.
I say that the next person to post in this thread....Well...YOUR MOTHER SMELLS OF ELDERBERRIES!
she does...
but at least I can color with a crayon, and stay in the lines, unlike the guy in the next post
I may not hold a candle to your kindergarten coloring skills but at least I don't have a tattoo of a Toyota emblem in the middle of my back like the guy in the next post.
I'm no turkey!
But the next guy likes Fram oil filters.
Yeah, I give them out as gifts to folks I don't like... like the next guy below...
I KNEW IT!
You're my secret santa!
Speaking of...The next guy ate all of Santa's cookies and kicked an elf!
Yeah but it was a mean elf.
The next guy has Tundra posters all over his room at his Mom's house.
EDIT: Oh yeah... good job Mike. This could get funny this weekend.
They're not Tundra posters! Those are bulldogs!
These type threads can turn into a real hoot if there are a bunch of people posting at once...Because the posts come in so fast, you never know what'll be said about you BEFORE you post. :uhoh:
The next guy will get turned into a NEWT!
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
