What Is This?
truckin
I got this off a late 90's Silverado extended cab. The item on the left is the one I am asking about. The item on the right is the bar that connects to spare tire lifting mechanism under the truck. The bar on the left was attached to the one on the right as shown in the 4th picture. Note that I have ground these both down with a wire brush and painted them gloss black with appliance epoxy so if you have these yours will look quite a bit different. I would like to know what the bar on the left is intended to be used for. I don't see how it could help the spare tire raising and lowering mechanism. The other odd thing is there is no where under the truck to secure this piece so its not swinging wildly and banging against the underside of the truck while driving.
http://i149.photobucket.com/albums/s47/sadman_the/unit1.jpg
http://i149.photobucket.com/albums/s47/sadman_the/unit2.jpg
http://i149.photobucket.com/albums/s47/sadman_the/unit3.jpg
http://i149.photobucket.com/albums/s47/sadman_the/unit4.jpg
The bar on the left, is a spare tire lock. It connects on the "tunnel" to the spare tire crank. Lower the tire, put the bar, with the loop on the tunnel, then raise the tire, position the rod through a lug hole on the spare, crank the tire up snug, and slide the lock up. You are missing the lock.
Ahhhhhh. :nono: I think I would be missing another bar of some sort as well as the lock then as I don't see how what I have in the pictures could lock the tire in place. I don't really see anyone attempting to steal my spare so I guess I don't need this. :idiot: Just for ><'s and giggles though, does anyone have a picture of their spare tire locked with one of these mechanisms so I could see what I'm missing. That way I would be able to recognize the pieces when roaming salvage yards.
Thanks for the fast reply.
I would recommend buying the lock and rod assembly at the dealer. The lock needs a key. I bought mine in 1999, for $20. at the dealer. This device, saved my spare tire, on my 1992 Gmc. The crank was to the ground and my spare was locked in place. Too bad, the thieves, had to find another spare elsewhere! :idiot:
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
