Oil Leak After Filter Change
Johnshan
I have a 2000 GMC Sierra with the 5.3L engine, I changed my oil yesterday and drove to work, when I got there my "Check engine oil level" light came on. I checked it, and saw nothing on the dip stick.
Come to find out, it had been coming out of the new oil filter where the o ring meets the "block".
I figured it was a bad filter, so I changed the oil yet again, and installed a different brand of oil filter even, got to work today, same deal again, oil gone.
It is leaking where the spin on oil filter o ring meet the engine. I examined the area and came up with nothing.
I have all 3 previous oil filters and all of them have the o rings still attached, and there are no other o rings left behind for that matter.
The filters are tight as well, I have done oil changes for years and never seen this, nor has my neighbor with the same truck.
Any ideas? Thanks guys.
I can't help you there... Never had that happen ever...Im thinking of going with K/N on my first oil change due to the ease of using a wrench and removing filter....
I'm assuming you don't have the original filter o-ring still clinging to the block.....that could cause a mess.....other than that I can't see how you'd be having such a problem.
Def no old o ring left behind. I am oiling the o ring up on the filter before I put it on.
Would over tightening a filter cause this issue? I just dont get it, been doing this for years.
This is odd, there are no defects on the block? It sounds like a sharp edge on the block is tearing the filters o-ring.
Not sure what happened, but I ended up getting a NAPA filter, and put it on "loosely" as in, not cranking it on like I always do, and it doesnt seem to be leaking now. I do not know if thats the reason why or not, never heard of a filter that was too tight leaking.
I've always heard that a too tight filter can leak, but have never seen it happen. Oil filters should only be finger tight, don't crank it on with a wrench.
+1 I always go hand tight, and I have never had a problem.
<----------------------- "knocks on wood!"
3/4 to 4/4 turn after gasket contact.
Never leaked for me.
I wiggle the filter as I screw it on so I can tell almost exactly when there is contact.
Thats the thing, it was only hand tight. I guess I dont know my own strength.
Time to knock off the steroids.
:banghead:
If the mounting surface is clean and flat, and you are installing the filter correclty, I would check the oil pressure guage while you drive it. Maybe there is a flow problem somewhere and the pressure is getting really high and forcing oil out of the seal.
Otherwise, you ought to make sure the oil isnt coming elsewhere around the filter area. I know you have looked but it never hurts to go again. I have been duped before on simple issues like this one, and the problem wasn't even what I was looking at for days on end. Check everything over above and around that area and definitely check the ground to see if you have wet spots.
I hope you find out what it is, this kind of a leakis well, not so good.
    DaleB
    DaleB
  • Who's Online   6 Members, 0 Anonymous, 1,441 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
