What Does This Wire Do?
I was at my friend's shop working. He has about 9 hunting dogs. Well one or a few of them decided to try and eat my truck.
They chewed the cover for the trailer connector and pulled this wire down (it mounts to the back of the plug harness box) and has a resistor(?) attached to it.
What is this wire and what is it for?
Do I need to replace it?
Thanks!
Truck:
2004 1500 silvy
tow package 4x4
Its for a third brake light on a trailer.
You don't need to replace it,Its suppose to be by itself like that.
Also thats not a resistor on the end,Its just a connector.
BTW...If any dogs ever decided to "eat my truck" they wouldn't be living much longer :lol: I'm not a big dog person as it is!
thanks for the help. I love dogs, but i would still kick the sh!t out of the dog that did it (if i knew which one it was).
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
