Can someone please run a vin check for me.
I would like to see what all service work was done on this vehicle please.
Thanks.
1GKDT13S452158496
GM Vehicle Inquiry System
Summary
Home - Summary - Claim History - Vehicle Build - Vehicle Component - Delivery Information - Dealer Information - Service Contract - Warranty Block - Branded Title
Help
VIN : 1GKDT13S452158496
VEHICLE INFORMATION
Merchandising Model : TT15506 -2005 ENVOY SLE 4WD (4-DOOR) Warranty Start Date : 04/05/2005
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : LARAMIE AUTO CENTER
PO BOX 1266
LARAMIE , WY 82073-1266
(307) 745-8961
Selling Source : 48 - GMC TRUCK
Site Code : 44400
Business Associate Code : 181452
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Type Number Description Posted Date Status
SB 06049 ONSTAR H/W IS DIGITAL-CAPABLE. NO UPGRADE IS NEEDED. SEE TSB 06-08-46-008. 02/22/2007 See Bulletin
EI 07238 FUEL CAP MAY NOT SEAL, MIL/SES LIGHT ILLUMINATED. REF. TSB 07-06-04-022B 04/22/2008 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped No XM Radio ID N/A XM Status N/A Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 04/05/2005 48 miles 04/05/2008 36048 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 04/05/2005 48 miles 04/05/2011 100048 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 04/05/2005 48 miles 04/05/2013 80048 miles
36/36000 FEDERAL EMISSION 04/05/2005 48 miles 04/05/2008 36048 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
05/20/2008 180035 # J0787 - TENSIONER AND/OR SHOE, TIMING CHAIN - REPLACE 39261 miles
01/31/2008 173522 # J4345 - COIL, ELECTRONIC IGNITION CONTROL (DIS/3CI) - REPLACE 35505 miles
12/15/2007 170938 # J0667 - BELT, PRIMARY ACCESSORY DRIVE - REPLACE 35397 miles
12/06/2007 170379 # J6372 - SENSOR, OXYGEN (ENGINE CONTROL) - REPLACE 35284 miles
11/13/2007 169048 # C3348 - FRONT SIDE DOOR TRIM PANEL REPLACEMENT - RIGHT SIDE 34483 miles
08/31/2007 164424 # J0690 - PULLEY, ACCESSORY DRIVE BELT IDLER - REPLACE 32095 miles
04/17/2007 155732 # J9991 - CUSTOMER CONCERN NOT DUPLICATED 27346 miles
04/17/2007 155732 # B1785 - ARM, WIPER - BACK GLASS - REPLACE 27346 miles
03/07/2007 153463 # J5650 - FUEL INJECTOR REPLACEMENT 26258 miles
03/07/2007 153463 # N9995 - CUSTOMER CONCERN NOT DUPLICATED 26258 miles
12/28/2006 149468 # J4206 - WIRES AND/OR BOOTS, SPARK PLUG - ONE - REPLACE 24247 miles
12/28/2006 149468 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS 24247 miles
04/18/2005 115942 # R0125 - RADIO REPROGRAM-SB 04-08-44-010 595 miles
09/17/2004 A58496 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 1998-2005 General Motors Corporation. All Rights Reserved.
Claim History
Help
CLAIM HISTORY
Repair Order Date : 05/20/2008 Repair Order Number : 180035 Odometer Reading : 39261 miles
Serviced By : LARAMIE AUTO CENTER
PO BOX 1266
LARAMIE, WY 82073-1266
(307) 745-8961 Selling Source : 48 - GMC TRUCK
Site Code : 44400
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
06/13/2008 908 01 # J0787 - TENSIONER AND/OR SHOE, TIMING CHAIN - REPLACE 12598504 - TENSIONER Y
Repair Order Date : 01/31/2008 Repair Order Number : 173522 Odometer Reading : 35505 miles
PO BOX 1266
Site Code : 44400
02/08/2008 872 01 # J4345 - COIL, ELECTRONIC IGNITION CONTROL (DIS/3CI) - REPLACE 12568062 - MODULE N
Repair Order Date : 12/15/2007 Repair Order Number : 170938 Odometer Reading : 35397 miles
PO BOX 1266
Site Code : 44400
12/25/2007 859 01 # J0667 - BELT, PRIMARY ACCESSORY DRIVE - REPLACE 12575216 - BELT Y
Repair Order Date : 12/06/2007 Repair Order Number : 170379 Odometer Reading : 35284 miles
PO BOX 1266
Site Code : 44400
12/11/2007 855 01 # J6372 - SENSOR, OXYGEN (ENGINE CONTROL) - REPLACE 12586996 - SENSOR N
Repair Order Date : 11/13/2007 Repair Order Number : 169048 Odometer Reading : 34483 miles
PO BOX 1266
Site Code : 44400
12/11/2007 855 01 # C3348 - FRONT SIDE DOOR TRIM PANEL REPLACEMENT - RIGHT SIDE 15776661 - PANEL N
Repair Order Date : 08/31/2007 Repair Order Number : 164424 Odometer Reading : 32095 miles
PO BOX 1266
Site Code : 44400
09/07/2007 828 01 # J0690 - PULLEY, ACCESSORY DRIVE BELT IDLER - REPLACE 24577515 - PULLEY N
Repair Order Date : 04/17/2007 Repair Order Number : 155732 Odometer Reading : 27346 miles
PO BOX 1266
Site Code : 44400
04/24/2007 789 01 # J9991 - CUSTOMER CONCERN NOT DUPLICATED N/A N
04/24/2007 789 02 # B1785 - ARM, WIPER - BACK GLASS - REPLACE 15908046 - ARM R/WDO N
Repair Order Date : 03/07/2007 Repair Order Number : 153463 Odometer Reading : 26258 miles
PO BOX 1266
Site Code : 44400
03/23/2007 780 01 # J5650 - FUEL INJECTOR REPLACEMENT N/A N
03/13/2007 777 02 # N9995 - CUSTOMER CONCERN NOT DUPLICATED N/A N
Repair Order Date : 12/28/2006 Repair Order Number : 149468 Odometer Reading : 24247 miles
PO BOX 1266
Site Code : 44400
01/19/2007 762 01 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS N/A N
01/05/2007 758 01 # J4206 - WIRES AND/OR BOOTS, SPARK PLUG - ONE - REPLACE 12598004 - SPARK PLU N
Repair Order Date : 04/18/2005 Repair Order Number : 115942 Odometer Reading : 595 miles
PO BOX 1266
Site Code : 44400
04/26/2005 581 01 # R0125 - RADIO REPROGRAM-SB 04-08-44-010 N/A N
Repair Order Date : 09/17/2004 Repair Order Number : A58496 Odometer Reading : 0 miles
PO BOX 1266
Site Code : 44400
09/21/2004 519 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
Vehicle Build
Help
VIN 1GKDT13S452158496
VEHICLE BUILD
Gross Vehicle Weight Rating : 2611 kg (5757 lb) Order Number : HJVWT9
Build Date : 09/17/2004 Build Plant : 15206
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AJ1 - DEEP TINTED GLASS AK5 - DUAL FRONT AIR BAGS
AL0 - SENSOR INDICATOR, INFLATABLE RESTRAINT AM9 - REAR SPLIT FOLDING SEAT
AU0 - REMOTE KEYLESS ENTRY AXP - MPV VIN IDENTIFICATION
A50 - DELUXE CLOTH RECLINING BUCKETS B30 - COLORED - KEYED CARPETING
B32 - FRONT COLOR-KEYED FLOOR MATS B33 - REAR COLOR-KEYED FLOOR MATS
CJ3 - DUAL ZONE HEAT & AIR COND C49 - REAR WINDOW DEFOGGER
C5N - GVW RATING - 5,750 LBS DAY - ASSEMBLY PLANT MORAINE, OHIO
DK2 - POWER/HEATED OSRV MIRRORS DT4 - ASHTRAY AND LIGHTER
EVA - EVAP EMISSION REQUIREMENT FE9 - 50-STATE EMISSIONS
GT4 - REAR AXLE - 3.73 RATIO G80 - LOCKING DIFFERENTIAL
JF8 - 4-WHEEL POWER DISC BRAKES JJB - SUBASSEMBLY
KG4 - 150 AMP GENERATOR K18 - ELEC AIR INJECTION SYSTEM
K34 - CRUISE CONTROL LL8 - VORTEC 4200 INLINE 6 CYL ENGINE
M30 - 4-SPD AUTO TRANS W/ OVERDRIVE AND ELECTRONIC CONTROL NP5 - LEATHER WRAPPED STEERING WHL
NP8 - ELECTRONIC SHIFT AUTOTRAC TRANSFER CASE NT7 - FEDERAL EMISSION SYSTEM
N40 - POWER STEERING N79 - STEEL WHEEL FULL SIZE SPARE
N80 - POLISHED ALUMINUM WHEELS PCK - ONSTAR PLUS PACKAGE * ONSTAR SYSTEM INCLUDES 1YR SAFE & SOUND * CRUISE CONTROL
QTM - P245/65R17 ALS BW TIRES R4Y - TIRE BRAND GOODYEAR
R6J - CUSTOMER DIALOG NETWORK R7E - INTERIM PRICE DECREASE
R9U - GM ACCESS-AUTOBOOK IDENTIFIER SLM - STOCK ORDERS
TB4 - LIFTGATE/LIFTGLASS BODY TFE - SALES INCENTIVE-COMMITMENT PLUS
T61 - DAYTIME RUNNING LAMPS T96 - FRONT FOG LAMPS
T98 - VIN IDENTIFICATION NUMBER UB0 - AM/FM STEREO W/CD
UE1 - ONSTAR SYSTEM INCLUDES 1 YEAR SAFE & SOUND UY7 - HD 7-LEAD TRAIL. WIRING HARNESS
U73 - FIXED MAST ANTENNA VK3 - FRONT LICENSE PLATE BRACKET
VXS - COMPLETE VEHICLE LABEL V73 - STATEMENT OF CERT. U.S.
YC5 - SLE DECOR YD3 - BASE EQUIP FOR SCH GVW PLATE
YD5 - FRONT SPRING - BASE EQUIPMENT YD6 - REAR SPRING - BASE EQUIPMENT
ZW7 - PREMIUM SMOOTH RIDE SUSPENSION ZY1 - SOLID PAINT
Z88 - GMC TRUCK NAMEPLATE 1SA - SLE STANDARD PACKAGE
1SZ - OPTION PACKAGE DISCOUNT 22U - SUPERIOR BLUE METALLIC
28H - LIGHT GRAY 28I - LIGHT GRAY
6HP - SUSPENSION 7HP
8NS - SUSPENSION 9NS - SUSPENSION
Vehicle Component
Help
Vehicle Component
Component Code : 10 - ENGINE ASSEMBLY
Source Plant : V - CPC FLINT, MICHIGAN
Part/Num Broadcast : NBP Traceability : 409141532
Date Scanned : 09/17/2004 Time Scanned : 01.09.00 Scan Station : 01
Component Code : 35 - STEERING COLUMN - SIR SYSTEM
Source Plant : S - SAGINAW DIVISION SAGINAW,MI
Part/Num Broadcast : U5H Traceability : 101172584
Date Scanned : 09/17/2004 Time Scanned : 01.13.00 Scan Station : 05
Component Code : 60 - TRANSFER CASE (4 WHEEL DRIVE)
Source Plant : N
Part/Num Broadcast : AH Traceability : 0BB411116
Date Scanned : 09/17/2004 Time Scanned : 01.18.00 Scan Station : 03
Component Code : 61 - TRANSMISSION
Source Plant : Y - HYDRAMATIC TOLEDO, OHIO
Part/Num Broadcast : 5TDD Traceability : 40111772
Date Scanned : 09/17/2004 Time Scanned : 01.14.00 Scan Station : 02
Component Code : 63 - FRONT AXLE/FRONT CRADLE WITH FRONT HUB ASSEMBLIES
Source Plant : G
Part/Num Broadcast : UP6 Traceability : CJI06474
Date Scanned : 09/17/2004 Time Scanned : 01.55.00 Scan Station : 12
Component Code : 65 - REAR AXLE ASSEMBLY
Source Plant : C - SAGINAW BUFFALO, NEW YORK
Part/Num Broadcast : AE9 Traceability : 252123354
Date Scanned : 09/17/2004 Time Scanned : 01.26.00 Scan Station : 11
Component Code : 92 - BRAKE PRESSURE MODULATOR VALVE ASSEMBLY
Source Plant : K - KELSEY-HAYES JASPER, INDIANA
Part/Num Broadcast : 7386 Traceability : 00425923
Date Scanned : 09/17/2004 Time Scanned : 02.44.00 Scan Station : 21
Component Code : AB - IR-MODULE ASM-INFLATOR
Source Plant : Q - RIMIR MATAMORS MEXICO
Part/Num Broadcast : 2397 Traceability : 1E0894C
Date Scanned : 09/17/2004 Time Scanned : 06.22.00 Scan Station : 06
Component Code : AL - IR-MODULE ASM-I/P
Source Plant : M - MORTON-THIOKOL
Part/Num Broadcast : 1178 Traceability : 9YAYS01
Date Scanned : 09/17/2004 Time Scanned : 00.51.00 Scan Station : 04
Component Code : CB - SEQ NUM (FLEX) BODY ASM
Source Plant : N/A
Part/Num Broadcast : 1ZZ Traceability : 0451132
Date Scanned : 09/10/2004 Time Scanned : 04.31.00 Scan Station : N/A
Component Code : CF - SEQ NUM (FLEX) PAINT PROCESS
Source Plant : N/A
Part/Num Broadcast : 1WW Traceability : 1059581
Date Scanned : 09/15/2004 Time Scanned : 13.02.00 Scan Station : N/A
Component Code : CK - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1PT Traceability : 1059239
Date Scanned : 09/16/2004 Time Scanned : 06.41.00 Scan Station : N/A
Component Code : CM - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1PH Traceability : 1058527
Date Scanned : 09/16/2004 Time Scanned : 19.13.00 Scan Station : N/A
Component Code : CP - SEQ NUM (FLEX) GEN ASM
Source Plant : N/A
Part/Num Broadcast : 1GB Traceability : 1058694
Date Scanned : 09/16/2004 Time Scanned : 20.58.00 Scan Station : N/A
Help
IN-SERVICE INFORMATION
In-Service Information Not On file
DELIVERY INFORMATION
Delivery Date : 04/05/2005 Delivery Type : 010 - RETAIL/INDIVIDUAL Delivered Odometer : 48 miles
PO BOX 1266
(307) 745-8961
Delivery Selling Source : 48 - GMC TRUCK
Delivery Site Code : 44400
Dealer Information
Help
INVOICE INFORMATION
Invoice Date : 02/12/2005
Site Address : LARAMIE AUTO CENTER
PO BOX 1266
Site Code : 44400
SHIP-TO INFORMATION
Ship-To Date : N/A
PO BOX 1266
Site Code : 44400
