Fuel Management
I don't want buy programmer. I would like to know if GM is going to reprogram the brains in my trucks so the AFM will stay engaged longer. If it is only 6% of the throttle range they need to up it more for the fuel savings and the environment like the commercial says. Can the GM techs help with this matter?
If GM does not provide the programming for it no,The techs cannot program something in that GM does not provide for.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
