Say Hello To The Newb...
Steve1968LS2
Nice site!
Just picked up a new '08 Sierra 1500 crew cab, though I would join to find out some info on it.
I had a '05 Canyon. Nice truck for hauling stuff but it couldn't tow to save its life. Hence the 1500.
The first thing I need to find out is how to lower the back of the truck an inch or so.
Here's my new daily driver:
Welcome! Don't lower the back.....raise the front :rollin:
It's not a 4WD, don't wanna be a pouser - lol
Nice truck, I mainly got it to tow my old Camaros when needed.
We (well..."I") need pics!!!!
Please. :sleep:
Welcome! Don't lower the back.....raise the front :sleep:
My bad, I had to take a second look ar the pic....I just caught on that it was a 2wd :rollin:
Please. :sleep:
Here's my "done" one.. '68 Camaro with an LS2 (550hp) and T56 trans. Corvette front suspension and three-link (with Watts) in the rear. She's a handful.
I just started on my other one for the magazine, fixing bodywork at this stage.
More pics of the orange car at www.fquick.com/steve1968ls2
Please. :sleep:
SICK.
EDIT: Okay, I went and looked at the other cars too. SON OF A BITCH! Those are some sweet rides. Very nice work.
Please. :sleep:
I hate you!!! :rollin:
:lol:
Please. :lol:
I hate you!!! :sleep:
:lol:
+1 :lol:
Welcome to the site. :rollin:
Please. :lol:
:lol:
See how EZ it is to make friends here?
Wow! Could I, uh, borrow your Camaro for a high school reunion coming up? :lol:
And welcome to our sorry world (most of us don't have the toys you have!) :rollin:
