Removing Pcm & Tcm
So I removed the PCM from my V-Max and is the TCM right underneath the PCM?
Here is the PCM, I need to remove them so I can send them out to get retuned.
Yep,Its on the other side of the bracket where the PCM is mounted.
BTW....The information we gave you was "classified",We are now going to have to hunt you down and kill you :cheers:
So I went back to the truck and pulled this out which I hope is the TCM
That is the one! You are set, brother!
