Electrical Problem
dhansell22
Recently my alternator died, my battery died, my high beams stopped working, and today my a/c stopped blowing. New battery, new alternator, and still electrical problems :lol: I pulled out the blower resistor and found this: a dime had somehow worked its way down to the bottom of the evaporator housing and shorted it out. You can see terminal E has melted and the dime has weld marks on it. What I'm wondering is what damage this has done. I think it is what killed the alternator but what's up with the lights? I checked them without the shorted part but the high beams still don't work. About a year ago I had the high beam/turn signal multi-switch and BCM replaced because of the same symptoms of no high beams. Did this short kill the BCM again?
dhansell,
I've had the same wire burn up on my 2000 ECSB 2wd, with no dime. I added in another ground wire that bypassed the harness (since my truck has 350k miles, I'm not concerned about warranty ;) ) and it blows again.
As for loosing the lights, does the security light blink all the time and will the battery die if you don't drive for a couple of days?
Check the TCM (actually for the BCM) in the lower left corner (as you face it) of the underhood fuse panel. I had a corroded and broken fuse in that location and caused a lot of screwy behavior, including no headlights.
Matt
