Mia
Whew... Glad to be back on the air after 10 days without electricity and a computer due to hurricane Gustav. Been through a many a storm but that was the worst hurricane i've ever been through. Utter destruction here in south Louisiana. Well just glad to be back and catch up on what i've missed since labor day.
Glad to have you back man... Now I'm looking down the barrel of IKE. Hopefully it won't do us much damage.
My house made it OK, even though I watched 80+ MPH winds whip outside. Lots of tree limbs, branches, leaves and debris. Been chain sawing, raking, pushing, pulling and just plain working my but off for a week. My moms house is going to take a little longer to clean up & fix damage, but well just plug along until the wife and I get it all done. Main thing is the electricity is now back on and things will start to get back to normal. The Silverado was in my shed and didn't get a leaf on it.
Good to hear you're alive and kickin' like a mule Robert. Heard from several folks from LSU about the storm down there, sounded rough for a spell. send some pics of the damage around town as time allows and when this site is 100% functional again.
Glad to hear you made it through ok. I guess that's why I don't live in those parts. Only thing we have to worry about around here is a little earthquake from time to time...
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
