How Long Have I Got?
I just gotta ask,
My tranny (4l60E) is whining/screeching just a little while shifting on acceleration. Everything else seems fine. No slipping that I can feel and I have all gears.
It also puts load on the truck when it is in Park.. not much, just enough to bump the truck forward a little when first starting (maybe normal?).
Can anyone tell me, in their best estimate, how long I have until rebuild? No towing or hard running.
OR can anyone tell me how to make it last longer before I have to rebuild?
Thank you,
James
Thanks for the reply!
No, it isn't slip yoke or U-joints. I know these issues pretty well.
No sir.. this is "hydraulic" sounding, comin right from underneath my butt (under the truck of course).
I think it is the front pump goin on me, but not sure.
Just wondered if anyone else has had this problem and how long they went before rebuild: or what they did to mitigate it.
James
Don't know...All the transmissions I've had go bad have been working like a champ one minute and not working the next.
This last one puked itself all over the highway, blew the pan out while it was at it.
Good Lord!
I hope that doesn't happen to me. (explode all over the highway)
I wished my life were that simple (as far as things breaking that is). Oh no.. I always have to go through all kinds of contortions and belly-aching and worrying over weird noises and strange activity.... THEN the part finally breaks. It would be nice if things would just let me know they are broken and be done with it so I could get on with fixing them. :cheers:
Thank you again.
Anyone else?
James
Yes indeed. That's exactly what it does. It lurches forward when first started!
Any ideas?
James
It's a miracle mine has held on for 150K miles. I beat the shit out of it daily still. The only thing holding it together is the increased trans pressure.
I have 166+k on mine, and I've never changed the fluid or anything. I guess I better knock on wood. :lol: Good luck with yours, and I hope it doesn't leave you stranded.
I have observed this on skidders and other heavy equip when started on cold mornings, but not with pickups. Doesn't sound good.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
