May Have Better Luck In This Forum
I think I might have posted in the wrong forum before as I can't even get a repsonse to the simple stuff - so since most everyone is over here - let's try a repost over here - below is a cut and paste form my previous post - i'm new to the forum and GM world - have had Ford before - but liked the newer Silverado's better.
Need some simple help and some not-so-simple help
07 Silverado LTZ Crew Cab - "Navigation Radio-AM/FM Stereo. CD, CD-R, MP3" - listed on sticker at 2250.00 (see attached file)-
1. in the sound portion on the menu - I have only the "Talk" option available - where is the other choices as the manula calls out - this is LTZ Equipemnt group - so it calls out the "Bose Premium Speaker system" - but even without it - shouldn't I have the other sound equalization options?
2. The system looks identical to other systems - including ones with DVD - so is this just some features that have been turned off - and if so will the lock pick unlock these features -
3. Can you callibrate the Nav system? - Mine appears to be slightly off
Thanks - I've attached the options section from the sticker - options_section.pdf
options_section.pdf
Hi there and welcome to GM Trucks!
Is the radio option you have have the U3U RPO code? There are a number of different Bose configurations where I believe the audio capabilities are dependant on the amplifier. I can't find an online owners manual to check, but it does appear that the manual may cover capabilities that are only available with the lux amp and not the premium amp. I know in my Dad's Escalade which has the Bose Premium sound system, there is only bass and treble controls along with fade and balance.
Yes, the non-DVD nav system looks the same as the DVD one, except it doesn't have the DVD logo. I also believe that the drive unit is only CD capable and also has software differences. Adding a lockpick won't give you DVD playback or give you features that don't already exist.
There isn't any calibration for the nav system I know of, your dealer may have more information.
First off - thank you very much for the reply -
Not sure what this even is or how I would know: "Is the radio option you have have the U3U RPO code?"
But, I am willing to figure it out - it sounds like your Dads caddy has the same as mine and so I'm starting to assume it is just the system that I have - don't really need the DVD or such as a aftermarket system was added to the headrests already - just a new truck (for me anyways) and I am checking out every bell and whistle I got and I guess a few that I don't.
You're welcome.
What I am meaning by the U3U RPO code is the option code for your radio. I would say that the option code for your radio (non-DVD nav) is U3U as listed model information book for your truck 2007 Model Info. You can also ask your dealer for a build sheet for the VIN of your truck which will list all the things it came from the factory with.
1.
My wife has the GM nav radio in her enclave. The owner's manual indicates that in the nav radio, only a preset "Talk" equalization is available. Probably the same with yours. Read your manual to be sure.
2.
Yes, I believe so. Do a search on this forum. I believe there was a post not too long ago that discussed this very issue, and had a link to the appropriate product to unlock all of this stuff.
3.
Not sure. Don't believe so. I have a TOmTOm myself, and I do not believe there is a user-initiable calibration. I do notice on the TT that every now-and-then it will "recognize" that it is off, and the car cursor will "snap" into the correct position all of a sudden, as though it did a quick self-calibration. :)
In having the opportunity to compare the GM in-dash system to a TOmTom, I must say that, IMHO, the GM system leaves LOTS to be desired. IT seems like they aren't using maps that are REMOTELY up-to-date compared with TT. I am still looking for functionality, in the GM system, that allows the compass direction to shift, such that North isn't always at the top of the screen. It gets tough when you are travelling south, meaning your cursor is travelling "down" on the Nav screen, to quiclkly figure out left from right prior to a voice prompt. I do not believe that the GM system allows you to set it up such that the cursor is always travelling "up" on the screen along with a compass to determine what geographical direction you are travelling.
If I am wrong, or have not found that function, please let me know.
1.
2.
3.
Not sure. Don't believe so. I have a TOmTOm myself, and I do not believe there is a user-initiable calibration. I do notice on the TT that every now-and-then it will "recognize" that it is off, and the car cursor will "snap" into the correct position all of a sudden, as though it did a quick self-calibration. :D
Thanks for the info - I will do the search - on your question about the heading on the NAV - on mine in the upper left of the screen on full view there is a little compass/arrow - if I press it - it switches between north up and heading up. Hope yours works this way as well as the north up is confusing.
options_section.pdf
options_section.pdf
I used to be an expert at this sort of thing, now it appears that GM made some modifications to the GMT900 series navigation (which inherently now support the GMLAN system). Yes as you point out, the compass can be 'adjusted' to directional or heading. The RPO code should be able to be found in the SPID lable in the glovebox. Yes the navigation system allows for calibration, problem is you cannot do it as a consumer. That has to be done either by the system itself or an individual that is armed with a laptop and the Tech 2 (GM Engineer). The older systems allowed for slight calibration.
though, I would simply recommend you rip out the old one and install an aftermarket...IMO...
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
