Need Help Quick Please?
Hi,
Here is my question:
5.3 ltr, 57,000 miles.
Runs fine except it kinda "stumbles" a little during idle.
Good accelleration and starts and runs fine. Slight ticking, but it is coming from the injectors way up on top.
Was checking out my lower tensioner pulley while the engine was running today (it's bad by the waybanghead.gif ). Looked up and noticed that my Crank Shaft Pulley was wobbling. Let me try to explain HOW it is wobbling. If you look at it from the side... there is NO wobble back and forth from the front of the block. In other words, the belt never leaves its straight track around all the pulleys at all.
BUT, if you look at it STRAIGHT ON from the front, the bolt and the pulley together have a slight side-to-side wobble.
Can anyone tell me if this is normal operation because of the cam action? Or am I in trouble? Like I said, there is no noise coming from the oil pan (stethescoped it), no unusual action from the engine except the slight stumble at idle.
Thank you to anyone who can give me any advice.
James
Yes Sir!
I went and watched it again for a long time. I even put a small dot at what I thought was the very center of the bolt head (hard to do exactly).
While watching it this time, I can't REALLY tell if it is an illusion of being off center and wobbly, or if it really is.
Have you ever watched one and thought it looked off-center?
I would think that if there was movement in that front bearing on the crank shaft, I would have an oil leaking or at least HEAR something going on.
Thanks for any help!
James
Keep in mind that harmonic balancers typically have a rubber cushion bonding two metal pieces together. Very slight wobble of the pulley may be normal.
If you were watching the crank pulley from the side, and it looked Good. then it is good.
It can't change by looking at from top. Otherwise, the serpentine belt would be fried. If I'm not mistaken there is No rubber on a gen three crank pulley.
Thanks for the replies Guys!
It did look just fine from the side (also from the top-down), I was just concerned that from straight-on from the front of the motor, it "looked" to be off-center. Since I think I would be having all kinds of problems if the Crank was moving around in its bearings, I'm gonna just chalk it up to an optical illusion and quit worrying about it.
Also, there is a rubber ring, albeit very thin, built into the harmonic balancer. At least on THIS 5.3.... but then again, mine came without an EGR system either.
Thank you again.
I'm still curious if anyone else have ever watched the bolt spinning around and swore that it was not rotating on-center?
James
Thank you again.
James
If there is a washer under that bolt head, it may not be centered properly and give illusion of wobble.
I'm done worrying about it. My mechanic said he has seen a slight off-center wobble lots of times. He said it "just happens" because of something to do with the self-centering bolt or something like that.
Also, it is very easy to see the the bolt in the middle of the balancer and crank pulley on the front. At least on my truck, I just drop down below the front bumper and look up at it....
Can't explain it any better than that. Maybe the lift and bigger tires make it easier, I don't know...
At any rate, no more lost sleep here.
Thank you again for all the replies!
James
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
