Hail Size Dents
I have 3 hail size dents on the door/hood. the are no larger than a quarter.. Although they are very annoying and would like to know if theres any cheap way to fix it.. I have tried "Pop a dent" which doesent work because the dents are too small.. I went to a body shop and they quoted me for 450. Any alternative?
Paintless Dent Repair. Find a local guy. I have seen a local guy do amazing things. I had a dent right on a body panel crease and he made it disappear. Probably going to pay around $400 in Chicagoland for that but I was truly impressed!
You have to be careful. Popping them out from the backside will leave waves in the panel. Stretched metal needs to be worked back to its original shape carefully. A good PDR guy can perform miracles. I'm about as picky as they come and I've seen some that can make a dent go away with zero trace that it was ever there.
Another big bonus about the paintless dent repair guys is no re-painting!!
Nothing like messing up a good factory paint job.
You will be much happier if the original paint is left intact.
Re-sprays are just never the same, don't look as good, don't last as long, etc.
My buddy is out of Columbus Ohio, and I'm amazed at the stuff he can get out and how good it looks. I had a used Cadi SLS a few years ago that had about 15 good sized door dings, it really looked pretty bad. He had all of them 100% out in 40 minutes, I couldn't believe it. :dunno:
He's an independent, that does a lot of dealers and retail.
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
