To Nerf Bar Or Not To Nerf Bar
I'm debating on whether or not nerf bars would look good on my truck. I asked my friends, some said yes, others said no. What are your thoughts? Any recommendations on what brand and where to buy?
Well that looks like a 2wd truck. so really you would only be doing it for the looks.. I have them on the black truck because they were a good price and the wife really needed them to get into the truck...
I need to get them for the D-max for the wife and myself since I have a bad knee! :lol:
They don't look bad on some trucks. A common maker is Westin. There are other higher quality steps. It just depends on what you want and can afford to spend.
I really like the N-FABS myself.
I have them on my truck, mostly so my wife and get in and out safely (she's quite short). But I like the look of them, and they are good for a step. I chose the Westin's, though the stock GMC nerf bars also look pretty good.
God no, they just dont look good on a standard pickup. If you have one thats jacked yes!
N-Fabs are really starting to grow on me.
I put the GM running boards on my truck (they're not shown in my sig - I really need to update that...)
I like the look of a running board a lot more than I do the nerf bar. Typically I'd agree that you shouldn't get them unless your truck is lifted, but my fiance wanted them to help her get in and out. And now that they're on there I'm a big fan of the look.
N-FABS are TITS on lifted trucks.
Stock height? Eh...
I just had some Westins put on last week. I do not like them. Had to put them on due to the wife being preggers and needing them for both in- and egress. I wish I had known about the N-Fabs. I saw them on here last night then saw them on a truck this evening. I might just have to order them and sell the Westins on the cheap.
If you want them or need them... Get 'em.
You're going to get so many different views on here about what type of trucks they DO work on or DON'T work on... Do what you want with your truck. If you think they look good, do it. If you need them because the truck sets a little too high, do it. If you need 'em for your wife or mother or mother-in-law... (Ok, well, maybe not the mother-in-law...) Get 'em.
If someone suggested it and you think it's a bad idea... "They just wouldn't look right." Ignore whoever suggested the idea and spend your money on something else.
:lol:
Post pics of what you do, if you get 'em! :D
I got the "Gladiators" from runningboardwarehouse.com. They look awesome! I'll have to take some pictures later. Some running boards I don't like the look of but its all just personal preference
i think nerf bars are only useful if you have a body lift.
then your nerf bars stay where they are and you actually have to step to get into your cab....
btw mine were on the truck when i bought it :thumbs:
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
