Amp Install Location In Nbs Ext. Cab
i have an 08 NBS Extedned cab 1500 Silverado.
i've already put in the Kenwood DNX-5120 In-dash Navigation/DVD system with some accessories and such.
I have the subthump dual 10" sub box across under the rear seats
anyone with the same setup have pics or advice on the amp install? ... is there really enough room on the back wall of the cab behind the rear seat backs? ... it doesn't look like it, but rather than rip all my seats out to find out there's not enough room, i wanted to ask others input first.
Thank you!
STEVE
thank you daddy. i've tried board searches repeatedly... i guess i was just cominbing all the wrong search terms... that's what i was looking for.
i already ran all the wires, have all the modules and adapters for onstar door chimes etc etc... install has been stupid easy and straight forward so far... sub box is done and mounted.
the sound quality difference between stock HU and the kenwood nav unit is night and day even with stock speakers. those will get replaces over christmas time ;)
amp was the last piece to the puzzle for now
have the back-up camera on the way
No Problem. Try the advanced search, it is much more useful than the default search box. We need photos of the truck and the install! :lol:
You can install the amp under the passenger seat as long as it is a manual seat and not an automatic adjustable seat. I have a dual sub box under my 07 nbs silverado and fits snug and installed the amp under the passenger seat bc i can get to the controls a heck of alot easier if need be. I also wired a sub control knob to the under seat lockable storage in the front so i can control the bass from the speakers with the head unit and the subwoofers from my hidden knob. Looks and sounds amazing. Ive got eclipse speakers and two kickers running off of my amp and it sounds beautiful.
__Chad
I always install my amps on the back wall behind the seat. If you don't want to drill through the back wall, a lot of people have used Liquid Nail to glue pieces of 3/4" MDF to the recessed portions of the back wall, and then mounted their amps to those boards.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
