Vegetable Oil As An Additive
ok, I have been looking into this for awhile now and I know there are multiple topics on additives and for that I appologize... In my old ('98) cummins (I know, I came to the dark side) I was running about a quart of straight off the grocery store shelf vegetable oil per tank. This came from talking to some OTR truckers that were running it at the rate of a gallon per 100 in their rigs. With the new engines, and the particulate filter and all that nonsesense, I am wondering if anyone has heard of, is doing, or otherwise knows anything about this practice. We have just over 1,000 miles on an '08 DMax. Thanks in advance,
I personally have never heard of OTR drivers running SVO in a tractor, but I suppose anything is possible. I am curious about this, what benefits do you see in running vegatable oil through the truck? In a older truck that is mechanically injected (and designed to run LSD) it would help lubricate the injection pump but why on a newer truck that is designed to burn ULSD?
In order for vegatable oil to burn properly it needs to heated to approximately 140*. Also, in cold climates you risk plugging up injectors, fuel lines, fuel filters, etc... On top of that, in trucks with any type of emissions equipment the glycerin in the vegatable oil has a tendancy to clog up egr valves, the vanes on VGTs, catalytic converters, etc... So I guess my burning question is......why? :jester:
Isn't this just like Bio-Diesel? I have a friend that owns a company that cleans up restaurant kitchens. He has several 55 gallon drums set up with some sort of heater gizmo for processing used cooking oil and then he filters it into a holding tank. I don't know what the mixture is that he uses (or what the actual procedure is) but I can ask him if you need to know. He runs his fleet of trucks on the stuff. His angle is that he saves money NOT buying as much diesel.
It doesn't sound much different than adding veggie oil. So we know it can be done.
I actually put in AT Fluid in my OTR rigs(Works great...but its kind of a no no so shhhh). But Yeah I have heard other owners/operators using Veggie oil in their PRE 2007 EMISSION rigs.
You definitely do not want to do this on a 2008 DMax. Run Lucas thats what my friend does on all his LMMs (3 of them) and his LBZ and LB7. His LBZ has over 100K and the LB7 has 267K
By the way I have two big ol' CAT engines and a Detroit Diesel 60 Series.
By the way 14.6L CATs('99 and '01) and 12.7L Detroit.('01)
Thanks for the replies everyone, to respond to a few of the comments from merlin, I am, in fact, in a cold climate (in the winter at least). I am not mixing anywhere near bio levels at only a gallon per 100 gallons of fuel. I guess that would be 1% if I am doing my math correctly. I have never experienced any problems, but as I mentioned it was on a pre-2007, which was my biggest question/concern. I appreciate the "no-no" on the '08 and that was what I was anticipating. The major reason for using it as an additive was the lubrication. It goes along the same lines as motor oil, although I was not comfortable with the used oil. I realize the older engines would burn almost anything and I am just not as familiar with the newer ones yet and that is why I am on this forum. Thanks again,
Close, but not quite. Biodiesel is a processed fuel. Vegatable oil in unprocessed. In bio-diesel, lye, methanol and other chemicals are added and the mixture is "cooked" to break down the glycerin strands (my main concern in running veggy oil) so they can be burned correctly. Also, most companies put anti gel additives in biodiesel to prevent issues.
Vegatable oil is just added in and burned as is. Veggy oil can be burned correctly in most (non emission controlled) diesels but it needs to be heated to flow and combust properly. Also, if done for a long enough time the glycerin has a nasty tendency to gum up the fuel system.
IMO opinion if the only reason you had to do this was lubrication, dont do it. The risk of plugged injectors, fuel filters and fuel lines is just to high, and modern diesels do just fine on ULSD. A lot of really good companies make great fuel system lubricants. If you wanted to save some money and convert an older diesel to run SVO then go for it. Good luck and keep us updated.
  • 3 weeks later...
I don't think it would work well in newer diesels. Like stated above it works for old mechanical systems, like in my 91 Jetta, this summer I was running a 50/50 mix of WVO and diesel. Sure was nice running for free. The jetta runs the same with it mixed with diesel. Now that the cold is here, I'm back to a super light mix of maybe two gallons of WVO to the tank.
    • Starting at 17 running parts for my father’s construction business to haul our equipment. Eventually doing shows, sales and training after purchase. I drove a minimum of 50K miles a year. Half hauling something. After retiring 30K miles a year to the last 2 years 15K miles a year. 2/3rds highway driving. The major contribution to fatigue for me is from anticipation and awareness. I just don’t relax. Too many idiots on the road. There’s two kinds. The group that never leave the left lane tied together afraid to let anyone in doing 80. They’re mostly on weekends. Then the left lane sleepers usually next to a tractor trailer not advancing. Eventually the tractor trailer will drift over the sleeper will wake up. The train moves and the tailgaters who are usually mad as hell. You definitely don’t want to mix with them. The tail wagging bumper puller’s with under powered trucks are holding the tractor trailer up. That bunch are dangerous. I usually pace ahead all that. Unless there’s a gap when I can chill and let the speeders pass. I tried all different types of driving. I stay to the right except to pass, it’s the law that’s getting in forced more now because of road rage. I was so happy when my wife didn’t want to do the camping life. I had enough of pulling for work. The family has a bus and fifth wheel. I haven’t driven either one since retiring. No thanks.
    • Yesterday a suggested youtube video thumbnail caught my attention so I watched through it and it was a bunch of short clips someone gathered together of people pulling trailers, a lot of them were bumper pull holiday trailers and a pickup or suv pulling it. a few fifth wheels as well, some motorhome crashes also. The tail wagging the dog theme was quite evident in numerous self inflicted accidents that took out vehicles around them sometimes in the process as the unit finally swung around and flipped over in the middle of the highway. Or the other classic which literally could be called "I forgot the trailer was back there" in passing another vehicle on a multi lane one way freeway and then cutting back in line before the back of the rv trailer had passed the front of the passed vehicle and often in front of a tractor trailer and that never ended well. Or the wide kick out swing of the rear of a long travel trailer as they have so much overhang behind the axles and the trailer smashes into the side of vehicles in the next lane over ( typically sharp turns in city driving ). It makes one leery for good reason to be near an RV trailer after watching a video like that and be it on the highway, in town, or at a gas station where that rear end comes swinging around due to the fuel station being so cramped and not intended for larger trailers. I wonder how many officers have heard those words though "I forgot it was back there" as they investigate the accident LOL.
    • $5.10 for regular at the Kroger   It's been 6 months... is this the "new normal" ?
    • Just because a person can buy a travel trailer or a motorhome doesn't mean they can drive it properly. My observation during my RVing years.
    • The cure for facism. https://imgur.com/gallery/cure-fascism-9DH3bHs
