Front End Clunk, Leveling Kit?
I am hearing a couple of "clunks" coming from the front end of my GMT900 it is not coming from the actual action of turning the wheels, it sounds more like C.V. joints, I have the rough country 2" leveling kit, could that have thrown off the angles that much that it messed up the C.V. Joints that quick, I wouldn't think so but I'd love to know if anyone else has been hearing this noise? it mostly does it with the wheels turned to the right. I would bring it to the dealer but the second they look at it you know what they'll say.
Is all the bolts tight? I never heard a clunk when I had mine installed. Did you have it aligned after the kit? You say turning of the wheels do you mean the tires turning or the wheels turning from the steering? I had mine on for about 3 weeks but I didnt like the angles of the steering joints from the rack and pinion and removed it, it also made my hood viberate at about 65 mph with the front airdam removed as I guess air was getting up and under the truck more and getting into the engine compartment making the hood viberate. Put the airdam back on with the leveling kit still on and still viberated. It was nerve racking and said screw it and remove the leveling kit.
yes I checked all the bolts, I did also have it aligned and I mean the actual tires turning after wheels are turned to the side
