New From Chicago
SUPRBURB
03 k2500 burb 6.0l 4.10's dual batteries 285/75/16 goodyear mtr's 1.5" spacers in rear 2" gm blocks i nrear cognito motorsports upper arm kit led bulbs all around
Welcome, we need pics of your truck, and girl friends... We also need a list of future mods... Ohh there are some assclowns here that will rag on you if you ask a question without doing a search for the answer first... Just ignore them.. Welcome to the forums!
