New Guy From Ontario
Cordanim
Hi all,
Just thought I'd introduce myself. Over lunch today I thought I'd check the web and see what kind of GMC Truck forums were out there, and this one stuck out as being a good community from looking around a bit.
While I'm not totally new to owning a GMC truck (just returned my '05 SLE crew cab lease), I'm the proud new owner of a sweet new ride and I think I'll be a bit more "involved" with my new one :eek:
Just picked up this baby last week - 2008 SLT "All-Terrain" - and, WOW, I just love driving this one. I find the new style drives much more like an SUV (I compare it to my in-laws' Envoy XL a lot I'm finding). The only "toys" it doesn't have are the nav system and the DVD player which I'm not too sold on anyway ;)
I hope to get to know you all over the next while. I'll be poking in often!
Kev
Here are the pics of my new "baby" :D
Welcome, and great looking truck. I love those all terrain wheels. :jester:
Got anything planned for it? If not, we'll make suggestions, and spend all your money for the next year and a half. :smash:
Got anything planned for it? If not, we'll make suggestions, and spend all your money for the next year and a half. :jester:
LOL not yet. I'm not much for additions myself other than the running boards that you see there.
I would love to hear what people think about mods though...preferably ones that can fly under the "wife radar" ;)
Well, in that case, I'd have to say a touch screen after market HU, a supercharger, a 6" lift and some 37's. :smash:
De-badge if you like the look, leveling kit (the rough country kit is well under $100 here, not sure about Canada), custom tune, there's lots more.
If she's good with a Tech2 scanner though, she would be able to find the tune. :jester:
Hi there and welcome to GM Trucks from a fellow Canuck! :jester: Nice truck you've got there.
You could probably slip in a CAI, a cat-back, HID lights, custom tune, actually a few things could be added in stealth. ;)
Hehe, I've actually thought of doing the HID lights...love the look of them...any recommendations? I'm a "mod" newbie ;)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
