Ipod And Bluetooth Interface
GRB
Hello There,
Is it possible to add a blue tooth interface and an Ipod interface on the same stock radio? I have an 08 slieverado with a raido that has onstar, xm radio, but is not the touch screen version.
  • 3 weeks later...
Hello There,
Does your factory radio have a small round plug on the bottom right corner - small black ring ?
If so; that is your ipod interface per the factory manual that I have for my truck 08 2500 hd. GM makes a cable to control the ipod just not sure on cost/performance; I do not use an ipod never have looked into the part.
I too want a blue tooth interface for my truck.
Scosche BlueFusion will allow you both assuming you have a Bluetooth transmitter for your iPod and that your phone supports it as well.
I looked into the blue fusion adapter, besides the cost it looks like a nice adapter. The reason I didn't go with it is it does not display any of the album or song titles on the radio...
Try icarkits.com for the iPod adapter.
As for BlueTooth, the Blue Fusion is the only one that I have found so far that is fully integrated, but damn is it pricey! For a less than optimal (but less expensive) solution, try parrot.com/usa.
Good luck! Please report back if you make a decision. I am still on the fence and could use some advice either way.
