What Is The Bigges Load/object You've Ever Pulled?
What is the biggest load you've ever pulled with your truck?
With my pickup I would have to go with logs that were 'felled' to clear land for a church. Mmmm, 4LO! :thumbs:
With a my old '94 GMC 2500 6.5L Diesel work-truck it was a Rosco Broom, and they weigh close to 6000lbs. They're heavier than they look.
GIT 'R DONE!
Not sure of the weight but when we cut trees down and use the truck to pull the tree out before we cut it in 6' lenths, 4 low and have had all 4 tires digging holes without the tree movin! even after a little jerk on the tree barely started to move. this is different then pulling a trailer because there is no weight on the truck, just using the trucks weight to move a tree. As for a trailer..... i dont know, maybe 5500lbs!
At the boat ramp
Sweet! What's in that thing Cat, Cummins, Detroit???
A Cat
Really my dads truck he owns a small trucking company here in Indianapolis and the boat has turned into a father and son project. There was no reason to buy a 3500 when we had semi's in the parking lot.
Not hauled anything heavy with my 1500 yet
I pulled out an F250 from a ditch. Heaviest peace of sh1t, so far. ..I know..its not a cargo container off the side of a cliff or anything... :thumbs:
Other than that, 'Bout 6000 lbs of paver stone.
At the boat ramp
A Cat
I'm a Cat guy myself. I used to work for Knife River Construction so I always got to play with the 'big kid toys.' I was especially partial to the T800 Wide-Hood lowboy with the 475hp 3406 Cat. Yeah, buddy!! :thumbs:
Supply order wasn't put in in time, so we did not get a delivery at work. I went to pick up our order and ended up hauling a 1250 lb. pallet in the bed. :thumbs:
Biggest load was a horse trailer with two horses,
Biggest drop was after white castle :thumbs::lol:
Heaviest I've moved with my '95 was my 'rents 42', 16,000 lb fifth-wheel. Only about 1600-1700 lbs of pin weight, but that's still quite a bit - it squatted the truck pretty darn good.
With my dad's 3500 dually, we used to move around 3 ton of gravel in the bed, or his 2500 lb truck camper. Never squatted past the overload springs.
To date, his F450 has only hauled that 42' fifth wheel and that 2500 lb camper.
