Goodyear Wragler Mtr Vs. Hankook Dynapro Mt
redneck_racr8
Looking online there have been ups and downs about the tires. Just seeing what anyone thought of the two. I live in Iowa so snow/ice driving is a big deal. Just looking for feedback. Thanks
Have you read the reviews ove on http://www.tirerack.com yet? Their reviews are from people that actually own the tires, so they are pretty reliable.
Jim's points out a great resource, but i'll throw my opinion in. If you're concerned about snow, and same for rain, stay away from the MTRs unless you plan on getting them siped. They don't do well in snow and wet because of their solid lugs. I don't know about the Hanook, but the Mickey Thompson MTZ or Cooper STT (which are nearly identical and both made by Cooper) are much better in the wet and snow. They're as aggressive a tire as the MTR, but have siped lugs. They're both a fair amount cheaper than the Goodyear as well.
^ What he said. I have the MTZs, and they've been a great tire. I have just under 12k on them, and with regular rotation, they are wearing extremely well. From the people I've talked to that had the MTRs, they said they wore quickly, and did poorly on wet and snowy roads (like Karl said, due to the lack of siping). Umberto (AllBlkdOut07) has the cooper Discoverer STT on his truck with similar mileage to mine, and they are wearing almost identically, and have been for the last 6 months (saw him in April they were the same as mine, saw him in Oct. and they were the same as mine).
And while tire rack is a good place to research all terrain and street tires, I wouldn't go there for mud tire reviews. I think they only have the MTR and the Firestone MT, neither of which have any siping, and neither of which are thought to be towards the top of the mud tire list.
Valid point... especially on mud tires. Tirerack's main limitation is of course the fact that they only have reviews for tires that they sell (obviously). Many 4WD mags offer up tire tests and reviews. I'd bet they even post them on their websites.
I completely forgot about those.
Check out fourwheeler.com and 4wor.com
I know both of them have done mud tire tests recently (and the liked the STT and MTZ).
Yea I checked tire rack and many others before i posted this. Many weren't just on Chevy trucks. Not so much that it would matter to much. I've also talked to many people around here that and most of them either have The hankooks or the goodyears. Most of them are famers. I just thought I would expand the question to more people. I thank you for the the advise and will now look towards the coopers along with the other two in making my descision.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
