Clear Water Drip
bevmale
Unfortunately my 2000 silverado extended cab has to sleep in my driveway.We have had some very cold nights and foggy wet mornings.This is the first winter that my pick-up has been left out in the cold.This afternoon I noticed water dripping out from just under the passenger side of the truck. It is clear water but I can't see there it is comming from. I know this is common from a/c condensation,however,a/c was not run today.Could it be accumulated dampness and condensation from mother nature??
Did you check to see if it had any taste to it? If none, I'd lean toward condensate from atmosphere.
Thanks txab..Did not taste yet,however it did not have any noticable odor.
Have you been running the motor to warm it up before you leave? I would lean towards window cowl drain or exhaust condensation leaking from a joint (if running to warm up).
--Mike
