JPG posting problem
chevy4x4trucks
Guys:
tried posting one of my jpgs at ClubPhoto and it worked fine in the test area.  When I try the same post in the General Forum I get an error -
"You are not allowed to use that image extension on this board. A valid format is: http://www.domain.com/picture.gif, an invalid format is: http://www.domain.com/picture.one.gif
Why does it work in the test area and not in the other forum?
I think clubphoto doesn't give you good links.  Check the link on the picture, does it even end w/ a file extension?  I know one of the photo places messes them up like that.  Try using web-photos.com if you're still having problems.
I would understand if it didnt work anywhere on the forum but when I preview it in the test area it works fine.  Just when I try to post the pic for real in the general area.  I have posted pics in the past (before the move to the new software) and they worked ok. This isnt the link I am posting but it is the same format and same place...
http://members8.clubphoto.com/_cgi-bi....&trans=
Why would it work in Test and not work in General???
It's like I said, it has no extension like .gif or .jpg  That's why they won't work when you try to post them in here.  They need to have a valid file extension.  That's one of the downfalls of club photo.
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
