This Is Cool
Zembonez
This is cool
If your eyes follow the movement of the rotating pinkdot, the dots will remain pink.
However, if you stare at the black"+" in the center, the moving dot turns to green!
Now, concentrate on the black "+" in the center of the picture. After a short period, all the pink dots will slowly disappear, and you will only see only a single green dot rotating.
It's amazing how our brain works. There really is no green dot, and the pink ones really don't disappear.
This should be proof that you don't always see what you think we see.
Very cool! I also got an after image of a ring of green dots when I finally looked away. It really is amazing how the brain works. The green is the colour negative of the pink. My guess as to why the dots disappear would be that our vision is motion oriented and our brain is trying to make it easier for us to focus on the moving object by "removing" unmoving distractions. The green dot being the negative of pink may be out brains trying to highlight the motion by changing the overall contrast of the scene.
:rolleyes:
Soooo... We never really saw Baglepuss?? :rolleyes:
NO.
Bagelpuss was a cruel mind control experiment played by Tobias (professional mind control expert name: DADDY)
I had this e-mailed to me awhile back. It's amazing how our mind's work. I bet that would've been a trip back in the 70's. :rolleyes:
HOLY SHIT!!!
Make me wonder how many things i "don`t see" and drive over at night in my service truck...... :rolleyes:
