4l80e Intermediate Clutch Situation
Need some help on my 4L80E rebuild. I have gotten pretty much everything buttoned up from the center support back. I went to install my intermediate clutches into the case and proceed to close up that assembly with the TransGo snap ring. After installing the snap ring I couldnt even turn the clutches with my fingertip, nor could I get a feeler gauge in behind the snapring to check a clearance! Thinking I did something wrong, I took the clutches out and put them back in and put the snap ring on. Same thing. My center support bolt as well as the cooler line were lined up on the money so I knew it had to be in my friction/plate assemblies. I mic'd my new steels and my new Raybestos Stage-1 waffled clutches (pictures attached) and found the difference was in the clutch plates (not the steels) stock looks like about .070 and my stage ones look about .090. I bought all the clutches in a kit and the rest went in like a dream. Why would they give me some crazy ass intermediates? I need these clutches as fast as possible and being a holiday weekend wittrans.com wont be back up until monday morning (the only place Ive found that gives me dimensions on the clutches). Anyone got any advice or even a solution on why I have one crazy set? Thanks!
Stock clutch:
Raybestos Stage-1 clutch:
Schmids5.3, yes I am putting a transgo reprogramming kit in it (the HD2 kit). It comes with a heavier duty snap ring, however it is not the culprit in this situation. They give you that because the stock one can release in a high RPM situation. I dont intend on anything high rpm, but Im putting it in for good measure.
Svensk, No sir, it is not a Z-Pak...At least I didnt get any information at all saying it was? They all came in a kit together (forward, direct, intermediate, 4th and overrun). Here is a picture of the friction kit I got before I opened it. The intermediates are at the very top, with the skinny overruns stacked ontop of them. Besides they dont make a Z-pak for the 4L80e.
...No wait...Isn't the Zpak one MORE? not one less, although one less would help the whole pack assembly shed heat better. Besides, Zpak is for 3rd gear holding power. 3rd gear is on the shoulders of the directs, which is the next assembly up from intermediates going towards the front pump.
EDIT: After reading the sales flyer or whatever you want to call it, off of the raybestos site, it looks to me like 91-95 had a different set of intermediates, compared to 95 up. Scroll down to page 4 if youd like to see what Im talking about:
http://www.raybestospowertrain.com/pdf/pro...1%20package.pdf
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
