Looking for clear side markers
Hello,
I'm looking for some clear corners that replace the yellow piece where the headlights are at.  Also how about them altezza style rear brake lights?  Some look good, and some don't.  But I haven't been able to find where to buy them.
Anyone got any ideas?
Thanks
Here's a few sites to try out:
www.jcwhitney.com
www.stylingconcepts.com
www.truckperformance.com
I think they should have what you're looking for.  If not, I've got a bunch more truck links for you to try, but those are the better ones... For parts at least, for info, nothing beats GM-T
