Modifying the stock radio
I have the stock in dash CD Player with a tape deck also.  I want to add a SAS Bazooka bass tub to the truck (the ones that are already amplified), and I am wondering if there are RCA jacks in the back of the stock radio?  I don't want to take the radio out to find out yes/no ( I was hoping someone already knew!).
thanks
I'm 99% sure there are no RCA jacks on a stock Delco radio.  Never took the one out of my '99 but the others I've seen didn't have them.  The General never plans for mods that we want....
Jeff
frank come over to
http://pub48.ezboard.com/bgmtruckchat
just watch out for the pop ups at first (i apologize).  We have a few stereo upgrade topics going.  There are a few guys who have done alot and are very knowledgible.  Also you do not need to register or sign up just post away
I think the hot ticket would be to locate the rear speaker wires.  Buy a four-channel amp, use the rear speaker leads to feed the amp, with a line-level reducer ahead of the amp.  Then feed the sub and the rear speakers off the amp with a cross-over to feed the right frequencies to each set of speakers.  Mount the amp under the rear seat or to the rear cab wall and no-one will know the difference...till you turn up the bass!!
Do you follow what I'm suggesting?  I can get more specific if you want.
Jeff
I've also heard that if you make your own enclosures for the rear speakers that they really have very good sound...  It's amazing that GM just sticks them in the doors like that.
Good info guys, I will have to consider the finances.  I am hoping to get the K&N Gen II Fipk, and was hoping to do a simple amplified bass tube, but perhaps custom enclosures would be a good temp fix, until I can do what 76BBSub is talkin about (which I follow you, and that is a great suggestion - if I go that route, I will definitely want more detail!).
Thanks.
  • 1 month later...
That looks pretty cool there, Smitty!  Where did you get that stealth box from???? Crutchfield?  Looks good, bet it sounds good too.
I got the box from a local shop here in FLA. It wasn't cheap though (about ?.00), the Silverado box comes preloaded with a JL 12" W3 sub, it sounds more like two 12" subs, no better way to go, it's worth the money. You can check them out at http://www.jlaudio.com/stealthbox/index.html
I'm also getting a baby EQ added today in the space where the factory CD player sits. I don't use the factory CD player anymore since I got a new deck, it just sits there . I will post pics soon. http://www.picturetrail.com/bsmith_tsg
(Edited
by Smitty00Z71 at 9:05 am on July 6, 2001)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
