Rear End Clunk
turbowilson
I have owned my new 2008 Silverado 4X4 crew cab for about a month now. I notice, most of the time, when I accerlerate from a stop, I hear and feel a "clunk" coming from the rear of the vehicle. Any idea what this is?
thanks,
Robert
thanks,
Robert
I've got the same issue ('08 Sierra CC Z71).... Mines going in the shop Friday, I'll let you know what they say.
I have it too. It really only happens when I decelerate quickly, so I am thinking it might be something with the rear drum breaks.
-Al
I had this on my 03 Silverado and my 04 Z71 suburban. It seemed worse on my Suburban, I can't rmember what the Tech called it but there is a bulletin out on it and it is considered by GM to be normal in all light duty trucks and SUVs and is more pronounced in 4WD vehicles. I noticed it when accelerating and decelerating. It was especially noticible when I was driving through neighborhoods or parking lots.
I have the driveline slack noise.... But this is different, I'll let you know what they say Friday. Mine pops, like the springs are binding or something.
Only after you come to a stop and then let go of the brake to accelerate correct?
-Al
-Al
The "slack" noise is at low speeds when you get on and off the gas like cruising through a parking lot and also starting and stopping.
My popping noise has disappeared now that the weather has warmed up a bit and it started raining. If it's not doing it Friday I guess I'll have to cancel the trip to the service department since we all know if they don't hear it, it doesn't exist...
Pull the rear driveshaft and grease the splines of the yoke with a good synthetic chassis grease (Mobil 1).
  • 3 weeks later...
Just a final update on mine. The noise never returned until the temp dropped back under 10*F. So I guess it's safe to say it's cold weather related and I will just live with it. I just can't tell if it's the leafs or the body mounts.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
