My Truck Is Like Zembonez
Yes, my truck whines like a little girl (and like Jim) when the temp gets extremely cold. It is going to the dealer next week for the following:
1. Cold weather front end rattle/clunk. Not suspension, but some type of clunky rattle in the engine compartment or front clip area. It's a resonance-type rattle when going over bumps in sub-20 degree temps. I have been chasing this the past 2 winters.
2. Pulley bearing whine/screech in sub-10 degree weather. Probably a tensioner pulley.
3. Climate control sensor fan, the little fan in the headliner right above the drivers head makes noise for a minute or 2 when starting in extreme cold weather after sitting outside all day.
It is supposed to be EXTREMELY cold here next week, so I am dropping my truck off Wednesday evening and letting it sit outside overnight at the dealer so they can start it up Thursday morning and experience it's "cold weather moodiness" firsthand.
F*cking GM sux, I shoulda bought a Tundra. :lol:
:uhoh:
Yeah and after that I think that I am going to take a dump!!! Off to the woods!
Yeah, right....good luck with that, Gimpy. :lol:
:uhoh: Yeah I wash it was still that easy! This will only be my second since monday!
:uhoh:Yeah I wash it was still that easy! This will only be my second since monday!
That's good to know. :D
It's because of the AFM.
Is this for real, or are you just kidding around? Hard to tell sometimes around here! :lol:
Is this for real, or are you just kidding around? Hard to tell sometimes around here! :uhoh:
:D
I'm fo rizzle.
:lol:
Until your truck gets to be nine years old and racks up 154K+ miles...stfu GMT800 FTW!
:lol:
<----------BTW Toyotas lead to sodomy!
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
    • I'm well aware of the typical bathtub failure curve, but plotted, this truck has been more like an elevated straight line.  It started days off the lot with misfires that GM couldn't solve for almost 2 years, and steadily continued over the last 5 years with repeat replacements of wiring harnesses, camera modules, cameras, parking sensors, head unit, rear windows, rear leaf springs and bushings, lower control arms, a radiator, and now an ac compressor and a column shift assembly.
