Billet Grills
How difficult are these billet grills to install on an '02 Silverado? Do I need to remove the radiator? I assume the old one gets cut out?
It's very easy to install.  All you have to do is remove a few plastic and metal screws and remove the stock grille.  It has nothing to do with the radiator, the entire front grille shell removes with only a couple clips and screws.   Then the new grille just bolts or screws on.  If you need specific instructions, just pm or email me.
[email protected]
Badass, You've got the exact grill I want! Who makes it? Any good places on-line to purchase aftermarket parts.  Thanks..
It's a Styleline Billet Grille.  I ordered it from www.Stylinconcepts.com  ...that's where I order everything for my truck. (exc. my exhaust, window tints, and wheels - I had all of those professionally installed)
Here it is: http://www.stylinconcepts.com/parts.c....60
If I had to do it again, I'd do the same thing and order the Styleline grille from Stylinconcepts.  I've had the grille for about a year and it still looks great.
