callyer Posted January 14, 2009 Posted January 14, 2009 So, as some of you may have seen, my mirror was bashed off by my local carwash. I decided to order some aftermarkets from AM-autoparts they are the tow mirrors, and are power like mine, however my mirrors are not heated, and these new one's are. So anyone have any ideas on installing a switch, or some other mod that may be able to make use of the heat function? Thanks, Craig
jrrod2004 Posted January 14, 2009 Posted January 14, 2009 So, as some of you may have seen, my mirror was bashed off by my local carwash. I decided to order some aftermarkets from AM-autoparts they are the tow mirrors, and are power like mine, however my mirrors are not heated, and these new one's are. So anyone have any ideas on installing a switch, or some other mod that may be able to make use of the heat function? Thanks, Craig I would say grab this from Muth: http://www.muthco.com/products/kits/200-0221.htm
jrrod2004 Posted January 14, 2009 Posted January 14, 2009 sorry the above is incorrect. the GMT900 is this one: http://www.muthco.com/products/kits/220-0275.htm (KIT #200-0221-0 H-MOD Upgrade Module $69.00 (plus shipping)
jrrod2004 Posted January 14, 2009 Posted January 14, 2009 if not, then wire em into a simple rocker switch and relay it to a switched power wire.
jrrod2004 Posted January 14, 2009 Posted January 14, 2009 Why do you need heated mirrors in AZ????? I knew somebody would ask...
jrrod2004 Posted January 14, 2009 Posted January 14, 2009 Why do you need heated mirrors in AZ????? He is going from HOTTER than HELL to COLDER than HELL From his profile: Chandler, AZ.. soon OH!
MS3DALE Posted January 15, 2009 Posted January 15, 2009 You better double check,I'm pretty sure your factory mirrors are heated,The switch for them is the rear-window defogger switch (IE-When you turn on the rear defogger the mirrors heat also)
callyer Posted January 15, 2009 Author Posted January 15, 2009 Why do you need heated mirrors in AZ?????If you kick them on in the summer here, you can use them as a camp stove!
