Chevy / Dodge / Ford / Toyota Comparison Video
In the process of it loading, I'm going to guess the Ford wins. They wouldn't show another truck winning in their comparison. At least Ford does include the others in their videos unlike the Ram. Will post back in after watching...
I was right...Ford won.
All competent trucks (except maybe Tundra) "Is the Tundra still attached to itself?" "Barely"
It would be interesting to see what the engine, suspension setups were in this. It would also be interesting to see a 3rd party compare everything. I'm calling BS, just because its a marketing video, and that's all marketing is. Same with the Dodge, GM, and Toyota commercials that call out the others. They all have a few areas they stand above the others and a few areas they fall behind. Lets see a neutral throw down.
I'll take my small block with narrow leaf springs and inset shocks over that ugly beast and mod motor any day.
If this is real Wow. Crazy! Good for Ford. This has been a truck many years in the making. For some reason ford just does not do anything for me.
Like somebody said last time this was posted, of course this makes the Ford look best, the test was catered to the strengths of the F150. I'd like to see a similar video, but from a third party.
x2, and one that shows which truck will do better over a longer period of time.
Wow.. the Tundra is about as tough as a flip flop.. that's about what it looks like on that course.
I watched those Ford videos a while back. I agree that they need to use third party testers if they want to be fair. I don't care what those videos show.. in 5 years that Ford will be in pieces. That's how every one I've ever dealt with ended up, anyway.
Careful now, you might piss off Dan (DV2000NJ). :rolleyes:
so all these clips on AutoInsane are not thrid party? Are they all done by the makers such as ford? Has any one asked autoinsane why they are showing only bais clips if they are not third party? Just want to know first time ever seeing these clips! :rolleyes:
All thanks to Toyota's sweet ass "TripleTech™" frame. With 3 frame sections, two C-channel (under cab and under bed), all bolted together.
Not to mention a v6 that will get worse than 19 mpg's on the highway! :rolleyes:
As stated in the article they are all made by ford. "Ford shot this video at their Michigan Proving Grounds"
and later "What do you think? Ford says the F150 is the best truck ever produced. Leave a comment below and give us your take."
Of course there is a bias, so take the videos with a grain of salt.
Lets face it...if you were to drive a Ford, toyota, dodge, and Chevy....i'm sure you can tell the diff. between them.
anyone who is in the market for a truck, will not test drive a truck because they watched the video and it was trashed.
that is my 2 cents...
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
