Silverado Front Bumper Question
I have an 03 Silverado with the textured black bumper cap. Are the smooth ones on the 2006-2007 Classics interchangeable with the ones on the 2003-2005s? I want to paint mine and it would be easier just to have a smooth one to paint. If they are interchangeable, could I have part number? Thanks.
I think I found the part numbers:
2003-2005 textured black GM Part# 15139805
2006-2007 primed, paint to match GM Part# 89025820
Hello Vortec-Z71.
I work in the factory where the GMT-800 Chevy Silverado front bumpers were manufactured and where the GMT-900 Chevy Silverado front bumpers are still being made.
The answer to your question is that yes, you certainly can take the textured black top cap off of your Silverado's bumper and replace it with a top cap painted to match your truck. I'm not sure if prepainted topcaps are still available in a colour to match your truck but if they are, that's the way to go. If only the preprimed top caps are available, then I would strongly suggest that you have it professionaly painted by someone who knows what they are doing with a special paint formulated for such aplications, as the plastic top caps are very flexible and a poor quality paint would crack or peel when flexing.
If you really want to remove the textured black top cap from your silverado's front bumper and replace it with a painted one, the easiest way to do it is to completely remove the front bumper off of your truck first and put it on some kind of work jig like a pair of well padded sawhorses or such. It probably can be done with the bumper still on the truck but it it would be so awkward to do that I wouldn't recommend it. You wouldn't believe what a biatch of a job it was to put those top caps on, both the textured black and especially the painted ones. Some men and women worked on that assembly line for years and never did get the hang of it. The folks who could do it properly were well rewarded to do it for those who couldn't manage it when their turn came up.
If you want to remove the textured black top cap in one piece and save it for possible reuse or sale, the easiest way to do it is to pinch the plastic carrots (tabs) that stick through the metal shell of your truck's bumper one at a time with a pair of pliers and gently ease each one out untill the top cap is completely off. If you just want to get the textured black top cap off and don't care about saving it, just grab the edge of the top cap near the wheel well and yank it off. Most if not all of the carrots will snap off but if your not salvaging the textured black topcap for further use or sale, then that doesn't matter.
Installing the new painted top cap is very tricky. To do this successfuly, you should start by pounding the carrot that is in the center of the bumper all the way into it's hole first and then work your way outwards one end at a time from there. You must be sure to align each and every carrot perfectly in it's hole first before pounding it in or you will risk snapping the carrots off and you will be buying a new top cap. a good use for your old textured black top cap would be as a practice piece. If you can safely remove and install the textured black top cap a few times without damaging either it or the bumper, then you should be all right with the painted top cap. At work, we used rubber mallets with the end contact surfaces padded with self adhesive foam padding to pound the top caps on with.
I wish you much luck with this project and if there is any way I can be of further help, please do not hesitate to contact me.
Cheers, lvlagnum.
Hello Vortec-Z71.
Cheers, lvlagnum.
I would not paint this bumper cap myself. I'm going to have the body shop do it along with a few other things. I'll probably go with the primed bumper cap as opposed to sanding down the old one (I've heard stories of them easily cracking). I'll have to see how much the body shop charges me to install the cap to decide if it's worth the trouble to do it myself. At least I know that the caps are interchangeable now.
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
