PowerTrax Lock Right
Wheel spin? gone. Traction? more than I'm used to.
I got on a curved highway on ramp, and after making the turn ontop a ramp, floored it. NO tire spin! NONE! just flawless acceleration. When making a turn while still giving throttle, the rear end feell more "pinned down " that it used to.  I can now give it good throttle from the start whitout having to worry about tire spin.
I get that review asap, I want to try it in rain(My biggest traction problem), and see what my 2WD can do on a steep hill, versus what my brothers 96 4X4 Jimmy can do on a steep hill still in 2WD, hoping I can match Powertrax's claim that this is mostly stick with a 4X4 with open diff's, while its in 4WD.
