satori Posted February 4, 2009 Posted February 4, 2009 Is there supposed to be a clamp on this tube on my intake? There's one on the left by the filter box, but it seems like there should be another one on the right side of the tube. If if matters, it's an '05 Tahoe, 5.3L.
CHEVIN Posted February 4, 2009 Posted February 4, 2009 Is there supposed to be a clamp on this tube on my intake? There's one on the left by the filter box, but it seems like there should be another one on the right side of the tube. If if matters, it's an '05 Tahoe, 5.3L. someone correct me if im wrong but i think its glued on.
goody93 Posted February 4, 2009 Posted February 4, 2009 yes there should be a clamp there, the flexible tube there is removable from the bigger piece to the right. Better get one on.
jrrod2004 Posted February 4, 2009 Posted February 4, 2009 yes there should be a clamp there, the flexible tube there is removable from the bigger piece to the right. Better get one on. +1 I just put my OEM back on and there was a clamp there.
Draenor Posted February 4, 2009 Posted February 4, 2009 Is there supposed to be a clamp on this tube on my intake? There's one on the left by the filter box, but it seems like there should be another one on the right side of the tube. If if matters, it's an '05 Tahoe, 5.3L. someone correct me if im wrong but i think its glued on. I think your correct.
Bowtie2Sierra Posted February 4, 2009 Posted February 4, 2009 yes there should be a clamp there, the flexible tube there is removable from the bigger piece to the right. Better get one on. +1 I just put my OEM back on and there was a clamp there. I concur...there should be a clamp on both ends.
dlstewart01 Posted February 4, 2009 Posted February 4, 2009 If that becomes loose and does not seal, you will get two codes. P171 and P174. lean on the left bank and lean on the right bank. guess how I know
jrrod2004 Posted February 4, 2009 Posted February 4, 2009 If that becomes loose and does not seal, you will get two codes. P171 and P174. lean on the left bank and lean on the right bank. guess how I know Hey you forgot your line.... Have a good one Don
CHEVIN Posted February 4, 2009 Posted February 4, 2009 how about this walk out to the thing and try pulling it off?? if it comes off you need a clamp if not its glued on.
jrrod2004 Posted February 4, 2009 Posted February 4, 2009 how about this walk out to the thing and try pulling it off?? if it comes off you need a clamp if not its glued on. that would suck if it is glued, just imagine if it gets hot enough, the glue would be sucked right into the engine
dlstewart01 Posted February 4, 2009 Posted February 4, 2009 how about this walk out to the thing and try pulling it off?? if it comes off you need a clamp if not its glued on. Its not glued on. I've took enough of them off. If you can't find a clamp I believe I have two or three of them in my garage, Have a better than average one Don
jrrod2004 Posted February 4, 2009 Posted February 4, 2009 how about this walk out to the thing and try pulling it off?? if it comes off you need a clamp if not its glued on. Its not glued on. I've took enough of them off. If you can't find a clamp I believe I have two or three of them in my garage, Have a better than average one Don
satori Posted February 4, 2009 Author Posted February 4, 2009 Thanks for the replies. I've sort of tried to see if it is a loose joint or if it comes off. It seems pretty solid, but I thought that might be just because it's stiff plastic. I guess I should go see if Autozone has a part number listed for it.
