Vett Servo
CHEVIN
servo??
19 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
i was thinking about doing a vette servo in my silvy but i have hurd that thay are bad and not do to do one. i dunno if i missed a post talking about this but i wana know what you think?
Do it. It will give you a firmer shift. I dont see any harm in it.
How bout you give it more than 53 minutes...? :uhoh: Not everyone's on during the day.
:uhoh:
I think there are way too many variables to be able to answer this question with a simple "Yes" or "No".
1. Tune (Shift pressures)
2. Vette Valve Actuator? I have been told this should also be added when adding a Vette Servo.
3. Truck useage.
I am sure there are others as well.
3. Truck useage.
i have hurd about the vette valve actuator. but what do you mean truck useage?
3. Truck useage.
Daily driver, hauling/towing alot, racing, etc.
3. Truck useage.
i see, i remember you trying to get as much info as you could about this (calling alot of trans shops) did they all say the same thing? should you have a tune if you going to be runing this to turn down Shift pressures?
I put one in before my BB tune :confused:
would you say i need a tune after i got it? how many miles do you have with it on?
I'm not sure if it's "required", but it's certainly "recommended" to accommodate for the firmer shifts & also to do an increase in line pressure is best.
There's about 4k miles on the servo right now, it has a wonderful snappy 1-2 shift :dunno:
I put one in before my BB tune :rolleyes:
There's about 4k miles on the servo right now, it has a wonderful snappy 1-2 shift :lol:
so i should be ok to run this with out a tune right? or atleast till i can one?
For me I wanted it to still be "driveable" and not break my neck or my input shaft, So when I press tow haul it knocks down the shift pressure a bit so incase of a heavy load it doesnt jolt the trans shifting. Its still firm but not insane. If im putting around or driving normally it shifts nice a firm but nothing too crazy. All in all I believe its how you get it tuned after the servo thats what makes the difference.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
