Exhaust Question
Hey everyone..I am wanted to add some horsepower and some sound to my 2005 GMC Sierra..Should I get just a good sounding muffler or dual exhaust. Also, what is exactly meant by true dual exhaust? Also, money plays a role in all this too..Thanks in advance..Lok forward to your replies..
if money is a factor just get a good free flowing straight through muffler like a magnaflow...i would stay from flowmasters and other chambered mufflers as they can reduce flow. the stock system on an 05 is probably pretty adequate except for the muffler...
but if money wasnt an issue i would get a single in dual out catback system. people dont go "true duals" unless they are like pushing out massive amounts of horsepower and you just have a stock truck. "true duals" are when the two exhaust banks are completely separate and never join. most of the guys on here have catback systems...me included...it was a good power gainer.
i had an exhaust shop chop off the exhaust in front of the muffler and y it off into pipes. take a look at my cardomain link in my signature. it sounds awesome and is not loud at all. 2 1/4 in. piping, 3 1/2 in tips 18 in. long.
yeah, agreed.
I have a dual catback from a muffler shop as well...cost me 400 including the muffler.
It's pretty cheap for the most part and does add a little power...but it sucks for Fuel economy...not so much that it makes you burn more fuel, as the upgrade will actually save fuel if driven right, but you want to hear it...all the time...so you always have your foot in it...
Oh well...what can you do... :D:P:P:P
My best friend has a nascar edition f150 and he had a flowmaster 1 chamber installed on there. That is a really nice sounding truck. We all had the one chambers on our mustangs and they were pretty dang loud but then again we didnt have any resignators or cats... just an off road x pipe.
I am really contemplating on putting a 1 chamber flowmaster on my 03 1500 i just bought. I know what they sound like on various fords but i would like to hear one on a chevy truck though.
I run a dual catback side exit flowmaster super40 system on my 5.3 and i can tell you they sound awesome ! Even with cats. I know alot of people like the magnaflow systems .....but it seems everyone around my neck of the woods has one so wanted to be different. Im not dissapointed in my choice at all.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
