First Time Owner
Brogan
Just bought my first full size pick-up last week, 08 GMC Sierra SLE Crew Cab 4x4 4.8L
This looks like the forum to be part of!
Im thinking of putting a cap on (Im in Ontario Canada and am thinkin it would be nice to have my stuff high n dry), any suggestions on best caps? pros and cons of a cap?
Also, pretty sure my stock radio can get XM, but what do I have to do to get it up and running?
Any help would be appreciated thanks!
Chris
Welcome to the site. If you bought the truck brand new, you should have a 3 month free trial of XM. The dealership should have set up this for you. Sorry, no advice on caps.
Thanks guys, no I didnt get the truck brand new, and I think I need some sort of module to get the XM up and running.
Welcome! I don't have a cap i just have a roll up tonneau cover and of the roll up I would recommend access brand covers. As for the xm you should be able to hit source untill you get to xm and just start listening if you truck is equipped with the xm receiver from the factory, as Scott said you should have 3 free months from GM if it is a brand new truck, heck i think they even do that for the used trucks that are xm equipped to.
I'd hang on and see what happens in the next month or so with SiriusXM.
In the mean time, do you have a DIC in your truck? Check my sig for details! :D
No I dont have the DIC and if its that easy Im going to look into putting one in! I've heard that SiriusXM is in trouble, Ive been a subscriber for over a year now with XM.
Thanks for the info much appreciated :P
It's that easy! :P
So is adding the garage door opener, the steering wheel radio controls and the turn signal mirrors. Plug-and-play! :P
Welcome to
I have a LEER cap on my truck, and I'm very pleased with it.
Thanks for the warm welcome guys, think Ive figured out how to post pics
the truck
and what I'll be pulling once the ice dissappears
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
