Cluster Replacement
I am installing a new cluster in my GMC.
As is my policy with all paperwork/contracts, I have learned to read thoroughly anything I sign.
THE POINT
GM vehicles store mileage data in several different locations throughout the vehicles complex electronic network of systems. In the event the vehicles odometer fails to display mileage, a licensed GM Technician can utilize a TECH 2 Scan Tool and access the ABS Menu to discern the vehicles true mileage. This information shall then be documented on form ODOM-4 "Statement of Facts / Odometer Disclosure form" by a licensed GM Technician and signed by an official representative for the dealership.
This was found on a form ICMOP-REV2.1
Several people have stated, and the general concensus has been, that the mileage is not stored anywhere on the vehicle other than in the odometer. This document states otherwise.
Corrections? Agree/disagree? New Info?
THE POINT
Absolutly dissagree, and the 30 year GM master Tech that used to be on this forum dissagrees also. On full size trucks only. There are other GM that keep mileage in the BCM ( Colorado, Canyon)
________________________________________________________________________________
http://www.gm-trucks.com/forums/index.php?...&hl=cluster'>http://www.gm-trucks.com/forums/index.php?...&hl=cluster'>http://www.gm-trucks.com/forums/index.php?...&hl=cluster'>http://www.gm-trucks.com/forums/index.php?...&hl=cluster'>http://www.gm-trucks.com/forums/index.php?...&hl=cluster'>http://www.gm-trucks.com/forums/index.php?...&hl=cluster'>http://www.gm-trucks.com/forums/index.php?...&hl=cluster
GM bullitin in this one on where it is kept:
http://www.gm-trucks.com/forums/index.php?showtopic=80996
In this one the GM Master tech prints out a copy of whats stored in the PCM (on 2nd page) and it ain't mileage.
This comes up every now and again, its BS. I worked in a GM dealer in 04 and 05. This would come up every now and again at the dealership. NONE of the Master Techs could ever find the mysterious mileage hideing any where EXCEPT in the IPC, cluster.
Don--------------------------------------------------------------------------------
more testimony
Well I've talked to several friends at the dealer where I used to work. One master certified and specialized in trim, Ie..clusters, bcm's electircal etc.. When I was working there we caught 2 people for Milege fraud, they cut the green wire going to the cluster and installed toggle switches so that the cluster would not track mileage. Both cases were investigated by both GM and the FBI, thats right the FBI. Both cases the correct mileage was unable to be verified. The engine hours were found but that only serves to tell hours of operation and can not determine mileage. My friends who I just spoke to said that to their knowledge the mileage is only stored in the cluster and if it is stored elswere that they would like to know how to access it with a tech 2. Also when a cluster is replaced under warranty it is ordered pre-programmed and shipped to the dealer and installed with no other modules being programmed. Without supporting info as to how to access mileage with tech 2 I will have to agree that it is only stored in the cluster
Not really an issue, just thought I would post the form sent to me. If anyone wants it, I will pm it to you. PDF file btw.
Yeah, I changed the clusted on mine to a OEM escalade cluster and I talked to the guys at my dealer and they said its not stored anywhere and that I would have to send both clusters out somewhere and they would transfer the mileage for me at the cost of $75. So as of right now, my 01 only has about 22k miles on it :D
2003-2007 milage is stored in the IPC
Various laws require that when an odometer is serviced, repaired or replaced, the mileage indicated is to remain the same as before this service, repair, or replacement. Where the odometer can not register the same mileage as before, the odometer shall be adjusted to read zero and a notice in writing shall be attached to the driver’s door frame of the vehicle.
I believe that would be 1999 through 2009 as well is kept in the IPC, instrument panel cluster
    • GM's are stainless and have a fairly robust powder coating, although, still not worth $850 in my opinion. They will hold up a lot better than their cheaper steel aftermarket counterparts.   What I like about the GM step bars is dealers will often equip their dealer stock with them. Lots of margin. Which means a lot of people end up buying them because they're already on the truck, even if they don't like them. So it's pretty easy to find brand new takeoffs with hardware on Marketplace and Craigslist for about $250.   That's what I did for my crew cab. I wanted ZR2 rock rails for the look, but with the ability to bolt up GM's assist step package. From GM it's about a $2500 accessory all in. The old folks in my life can't get in the truck without steps. I found the whole package on marketplace for $180.
    • I am really glad I found this post and this site... We have a 2022 1500 refresh LTZ that has these problems: - forward collision avoidance warning light - lane keep assist unavailable - adaptive cruise control unavailable   The truck was bought as a new leftover in 2023, so it was still under the 3/36 B to B when it went in for these problems earlier this year. It has been at the dealer on and off now for about 110 days now. These are some of the things they have done that I can read on the service tickets. - replace/add ground straps (4) - check all battery cables and vlts - replace serial data gateway module - replace front view camera - numerous reprogramming - a few calibrations (apparently ending with 'learned') Last week when I had it back the truck had those 3 warnings every time we used it except for 3 times. On three separate occasions the truck started and ran perfectly with no (zero) warning messages or warning lights lit - everything worked perfectly. Over that same time period the truck did not work on every other 'key' cycle which I would estimate at 60+ cycles. On those estimated 57 cycles it had the same 3 problems each and every time.   It is back at the dealer now - can anyone help at all with what the true problem might be?  Or possibly what can be ruled out leaving a lower number of possibilities? Thank you very much for any help you may be able to supply....
    • As for the step bars, friend did just that, bought some cheap ones and we are in Michigan and they turned to rust in less than a year.  In 3 yrs he had to replace one of them because they rusted out from the inside even though he kept after them cleaning and polishing etc. Had to drive 300 miles (to Chicago area) to find a reg cab wt, he ordered one and dealer never got it and with winter approaching (plow truck) he needed fo find one ASAP.  Furd dealer found him one but he choose to drive to get a GMC.    Just what you can expect with cheap stuff, LOW quality.
    • I’ve seen many times people over buy to start a business. Instead of quality equipment they buy junk and drive an expensive truck. Our first haul truck was a 2 ton wrecker with 6 cylinder to haul our equipment. It would go 60 miles per hour flat out. Our trucks were older trucks we could work on easily. Our equipment was first class that we could work without fear of breaking down. You could always use large trash bags to wrap for water proofing. Put the money where the return is. Comfort and luxury comes with success. Good luck in your venture.
    • Thank you, it looks like I have to get a topper or a box van.  Unfortunately, the only vans that can tow what I am looking for are going to be 3/4 ton vans, which may ride rough if I am going to use this on the road extensively.  I may also use it to take marketing clients out on the road.   Not knowing anything about starting a business, my goal is to start small, use things I already have & keep everything in good working order.  I have a small box trailer, need to install lights in it, and same for the topper itself.   How easy does Chevy/GMC make our trucks to upfit if we decide to add things like a topper and lights?  On Fords, the upfit process was rather easy.  Just tie the +12V of the lights to the AUX relay panel and the - to chassis Ground.
