Going To Look At This House
BuckFeverZ
http://firstweber.com/vp/ListingServlet?SI...;cd_MLS=1189639
Nothing terribly special, although I wish they pics of the inside. One thing that sucks is there is no garage, but I would add a 2 car garage if I did end up moving there.
I do like the fact it's out in the country and nobody would be bothering me and it's in my price range :confused:
Thoughts?
Nice, would you build a garage?
Thoughts?
Umm...:rollin:
Not a bad price, and I am sure you can pick up some old tires, kitchen appliances, old bath tub, junk cars on blocks, etc...... nice and cheap to spruce up the yard nicely. :confused:
Looks good. When buying a house you want to make sure it has decent potential resale. I like the idea you have of putting a garage on it. Check for things like mold, sturdy foundation ect., also consider what a girl would look for when she is buying a house. Decent closet in master, large enough kitchen to cook, and you might want to consider adding another bathroom or something down the road. All just things to think about when buying. Hope you like it!
From the picture it doesn't look too bad. I'd be adding another bathroom as well as a garage. Given it's an older house be sure to check the foundation, basement, attic, and window sills for signs or deterioration of the wood. Also if you can ask the owners, see what their heating costs are. See if they have any problems with water encroachment/flooding. Check the condition of the roof. Check the ceilings and walls up stairs for signs of water damage from a leaky roof.
All great advice. I am a carpenter by trade, so some of this stuff will be easy for me to look at. Plus, I would have my buddies dad come with me and inspect it since he is an inspector for the state.
Oh, and......Hi there and welcome to GM Trucks :rollin:
+1 :confused:
Link doesn't work.
That's probably a good thing. :rollin:
GTFO :confused:
You misunderstood the joke Scott, I was referring to Jas's little "mishap" involving a house. :lol:
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
