A.c. Issues
I have a 2003 2500HD that seems to be having some Issues. Last year the air cond. Would cycle cold to hot and back randomly. I was under the truck the other day and found a belt sitting around the bottom of the engine. Called the mech. he said the compressor probably seized. That is the only time he has seen the belts break like that. Any way to test this theory or is that probably the issue?
Thanks in advance for any ideas.
The belt brake, or did it slip off? If the compressor seized, youll know it when you run the engine.
Yes the belt was broken. Do you think it was a loose or broken belt that is to blame?
